Old 12-05-2016, 07:32 AM
SiriusDragon SiriusDragon is offline
Unhappy SR-2 NF200 problem
So I managed to get an SR-2 but I'm having issues with one of the PCIe slots.
The 2nd x16 slot down (ie. Slot 3 of 7) is showing graphical corruption in Windows and on boot. While if I put a card in Slot 1, that slot is fine and the card in Slot 3 isn't even recognised in Windows
nvflash is returning odd results... It seems to pick up the cards but then says something like "Unconfigured display adapter found. Device not accessible" in reference to a BR04 device, ie. the NF200 chip
Is it possible something is wrong with the NF200 so one x16 slot works and the other doesn't? Is there any way at all I could fix this? eg. Flash the BR04 using the bios from the other BR04?
I'll be kicking myself if this doesn't work... I specifically got the board to run (and oc) 4 video cards
Edit: To rule out software issues I'll try booting with my Fedora USB stick and see if I get the same problem...
Old 12-06-2016, 05:20 AM
Ok, so... 3 way SLI works with cards in slots 1, 4 and 7.
2 way SLI works in slots 1 & 4.
I tried using PCIe 3.0 risers to run 4 way SLI in slots 1, 4, 5 and 7 but the motherboard refused to recognise the cards. These same risers worked fine with the X58 4way Classified and the same video cards. Even a single GT610 on a riser in slot 1 didn't work
So yeah... I'm guessing it's dead/broken as far as 4 way SLI goes and there's nothing I can do?
Anyone? It was a pain the arse to get this board.
Old 12-06-2016, 05:40 AM
Check if all pins in slot are OK and little capacitors near slot are ok (many of them, grouped in pairs). If any of them damaged - you could have no detects as you described.
Old 12-06-2016, 07:28 PM
Thanks for the advice TiN!
I'll have a close look at everything. Would that explain the graphical corruption, eg. a loose cap or bad PCIe slot pin?
The board was shipped without CPU socket protectors (!) but the CPU sockets look OK and all 3 RAM channels on both CPUs get picked up, so I don't think it's the CPU sockets at fault. So that leaves the NF200 or the other electronics around the PCIe slots I guess.
I'll try and have another poke around with it on the weekend or later this week.
