Old 11-14-2016, 08:28 AM
foreshopping foreshopping is offline
Originally Posted by k|ngp|n View Post
I'll see what can be done alright? I understand that overclockers like to tinker
Over 1.2v I think provides little to no benefit with pascal 1080 gpus on air. Most cards will hit the thermal throttling limit even at max stock p0 voltage on air cooler in a case before it will hit its "silicon limit". For daily use I can't really see much real world benefit to that on air cooler. Maybe with good WC temps the benefit slightly increases yah. Then on Ln2, card will need more. No OC/XOC bios out there probably because of overvoltaging issues/limitations whatever people want to call it with 1080. Ask any ln2 overclocker about 1080 and see what they say about how the card scales. Even on Ln2, these guys are using relatively very low voltages. I really could care less what other NVIDIA board partners do, that has nothing to do with my personal overclocking efforts or what goes on OC wise for evga customers (bios, fw, etc). We do our own thing here.
Higher pl might benefit more, not adding more heat to hard overclocked gpu. A 1080 at 2ghz+ with stock voltage and no power limit will just heat up and heat up until the clocks start to throttle. An increase in core voltage to 1.25v won't help that. NVIDIA released an amazing gpu that hits nearly 2.1ghz on air at such ridiculously low voltages. I never could of guessed this gen would be capable to match 980ti Ln2 clocks on air. That is crazy oc wise. Guess we just always want more huh?
Is there any OC/xoc bios floating around for classy at the moment?
I put up an evbot FW for 1080 classified
hi kingpin, the thermal throttling is due to the gpu boost 3.0 right?? so is there any ways to disable the gpu boost on pascal cards just like what maxwell bios tweaker does???
i saw your last gtx 1080 ln2 overclocking, your gpuz pic showed that a gpu boost disable bios was using. but your latest titan x pascal ln2 overclocking used the original gpu boost 3.0 bios without locking the core clock to 2000mhz. would you tell us the differences from using boost-off bios?
thanks a lot.
Old 11-14-2016, 08:42 AM
Uing's Avatar
Uing Uing is offline
Originally Posted by alientek View Post
Could this tool change the voltage of EVGA 1080 FTW?
Classified/KPE cards only.
Old 11-14-2016, 12:00 PM
alientek alientek is offline
Is there no chance to get this to work with other EVGA cards? this is the best shot everyone has
Old 11-15-2016, 05:17 AM
Uing's Avatar
For other EVGA 1080 cards, you can flash the Strix_T4 BIOS, this bios removed the power limit and unlock the FBVDD.
Old 11-22-2016, 08:40 PM
Hows going over here? Any updates? Been slammed this past week and away form the forum.
Old 01-13-2017, 01:17 PM
fat4l fat4l is offline
Would be cool if this "tool" could also work with FE card too
Old 01-29-2017, 01:50 AM
Vellinious Vellinious is offline
I've managed to get some really good clocks / scores, but...I'm at the limit of the stock voltage. I've begged EVGA to release a bios, as ASUS did for the STRIX, but, alas, it doesn't look like they're going to commit to their customers as well as ASUS has. Oh well.
Single card at 2278 @ 1.093v
SLI run at 2252 @ 1.093v
A little extra voltage sure would be nice.... /smdh
Old 01-30-2017, 05:44 PM
nrpeyton nrpeyton is offline
I second this.
And I would also urge the community to follow.
Some of these cards (like Classified) even feature "LN2" printed next to the BIOS switch on the card.
Even ASUS, released an LN2 BIOS. So why can't EVGA?
What about a system where by you can request an "enthusiast key" from EVGA? Which is required to unlock the new BIOS? This would have have an impact on warranty claims. And users are encouraged to overclock at entirely their 'own risk' ?
For guys who want to get into the LN2/DICE overclocking scene, EVGA really needs to begin supporting these people.
It seems utterly ridiculous that ASUS support this; but EVGA doesn't.
This is when the community begins to turn to Vince for help :-)
I am looking forward to the new evbot, my card has the connection port for Evbot for this -- so i am lucky. (and also patient) :-)
But for FTW owners, a nice BIOS, would be fantastic news for the overclocking community :-)
Kind regards :-)
