Old 07-16-2015, 03:46 AM
Default KINGPIN 980Ti // Titan-X // NV 980Ti Performance Comparison
Here are the perf numbers for Kp980Ti and how it stacks up against NVIDIA reference 980Ti and NVIDIA Titan-X in 3DMARK Firestrike xtreme and Firestrike ultra benchmarks. I included Overclocked scores using 1430mhz on all 3 cards as well as default "out of the box" scores which are basically what you get without doing anything other then plug card(s) in and run. This is NOT the default shipping clock/spec of KP980Ti, that will be announced soon. Should be between 1430-1480mhz for most cards. I used the low end(1430mhz) clock on the range for KP for the Overclocked results anyways.
Same system used for all tests and these are my everyday settings for most of the vga testing I do daily
Test setup:
5960x @4.5GHZ
EVGA X99 Micro 995
Quad channel ddr4 3250mhz
Windows 8.0
NVIDIA Geforce Driver 353.30 WHQL (No driver or OS tweaks used at all anywhere, just plug in card, install driver, enable k boost, set max fan, and bench). The vga bios of all three using the same settings. Unlocked power and fan limits only.
Default out of box scores, 1200/3505 base clock:
NVIDIA Reference GTX 980Ti
NVIDIA Titan-X, 1200/3505 base clock:
Overclocked results using same gpu clocks on all three for good clock--clock comparison of how these vgas stack up against each other:
NVIDIA Reference 980Ti 1430/3505
EVGA GTX 980Ti KINGPIN 1430/3505 (below anticipated offical card spec)
You can see clock to clock its faster than reference 980Ti(and probably all other custom Ti's) and nearly at Titan-X perf level in its current state. We are performance tuning the card now in hopes for a little bit more by launch, lets see. The card is faster than 980ti reference for a few reasons, we will detail more later
NVIDIA TITAN-X 1430/3505
OK enough air results, how about some LN2?? I can't think of a better way to celebrate EVGA's 16th anniversary then with some single card records beating Titan-X on KP 980Ti
Old 07-16-2015, 03:57 AM
Here's summary of results above with more easy to read graph
Old 07-16-2015, 04:08 AM
Very nice ! Good job Vince and TiN
Old 07-16-2015, 05:07 AM
Szeged Szeged is offline
awesome cant wait to finally be able to order them, enough teasing im about ready to blow :P
Old 07-16-2015, 07:41 AM
Xtreme Addict's Avatar
Xtreme Addict Xtreme Addict is offline
Great efficiency bios! I guess efficiency will scale with higher clocks? So at higher clocks it will match/outperform TitanX clock per clock
ASUS Polish Overclocking Championship 2010 #1st
MSI MOA 2012 EMEA - #1st
MSI MOA 2012 WW FINALS - #7th
ASUS Open Overclocking Cup AOOC 2012 - #1st
MSI MOA 2013 EMEA Qualifier - #2nd
ASUS Open Overclocking Cup AOOC 2013 - #3rd
MSI MOA 2013 WW FINALS - #3rd
Galaxy GOOC 2013 Finals - #12th
HyperX OC Takeover HOT Final CES 2014 - #1st
G.skill OC World Cup 2014 - #3rd
HyperX OC Takeover HOT 2014 Computex - #1st
Intel OC Challenge Computex 2014 - #1st
MSI MOA 2014 WW Finals - #12th
ASUS Open Overclocking Cup AOOC 2014 -#2nd
Galaxy GOOC 2014 Finals -#4th
HyperX OC Takeover HOT Final CES 2015 - #1st
G.skill OC World Cup 2015 - #5
Old 07-16-2015, 08:34 AM
Pgcmoore's Avatar
Pgcmoore Pgcmoore is offline
Awesomeness!!!!
"EVGA GTX 980Ti KINGPIN 1430/3505 (below anticipated offical card spec)
You can see clock to clock its faster than reference 980Ti(and probably all other custom Ti's) and nearly at Titan-X perf level in its current state. We are performance tuning the card now in hopes for a little bit more by launch, lets see. The card is faster than 980ti reference for a few reasons, we will detail more later "
looking forward to the release of this for sure,
gonna go pay off the CC so theres no problems on there end, I think I will get 2, not one as planned
now, to let the wife know,,,,
Old 07-16-2015, 08:46 AM
Perica_barii Perica_barii is offline
Send a message via MSN to Perica_barii Send a message via Skype™ to Perica_barii
Really great card
Old 07-16-2015, 08:54 AM
ssiperko ssiperko is offline
So hott!
SS
Old 07-16-2015, 08:56 AM
Forgiveness is easier to get than permission ....... 36 years with the same woman here .... trust me.
SS
Old 07-16-2015, 09:11 AM
hallowen1's Avatar
hallowen1 hallowen1 is offline
Looking pretty good, even though as Vince stated it is "nearly at Titan-X perf level in its current state".
IF I manage to make a purchase, I'll still want to run my own OC/Benchmarks using similar settings/cooling components I had with my Titan X just for comparison which is why I'll be needing only one KPE to start with.
It will be very interesting to see what the Final Specs are when released.
