  #71
Old 07-26-2015, 09:14 PM
Not yet, 980ti kp is whoring all my time but i haven't forgotten about its little brother
Old 07-27-2015, 09:24 AM
ssiperko ssiperko is offline
Fully understandable. Thanks.
Kinda curious about possible memory stuff like was talked about on the Ti.
SS
Old 08-07-2015, 07:14 AM
Default Classified tool question
When I use the Classy tool to adjust memory voltages my system freezes often requiring a hard reboot.
When I adjust it from the default setting of 1.395 it goes to 1.5 and will not allow a lower setting until a default restart.
It's my understanding 1.5v on memory is safe, yes? No?
SS
Old 08-07-2015, 07:36 AM
1.5V is actually below the stock value of 1.60V. First, set to 1.6V and then go up from there.
Old 08-07-2015, 01:14 PM
Hum .... OK ..... wonder why the classy tool has the default setting so low?
Out comes the DDM's.
SS
Old 08-07-2015, 06:29 PM
Yeah I was having the same issue. Even if it shows the 1.395V, it has the default 1.60V set. Once you've set it, it should set on restart again.
Old 08-08-2015, 09:10 AM
Got it thanks.
Now to see how far the memory will go.
SS
Old 08-15-2015, 03:24 PM
Originally Posted by ssiperko View Post
Got it thanks.
SS
Upto 2200 at 1.675v
SS
Old 10-14-2015, 11:10 AM
Scarlet Scarlet is offline
Hey boss, just tried to modify the stock bios ever so slightly. Just bumping the values up slightly to see if I could cure some minor artifacts that started occurring occasionally.
After updating the values and loading the bios, then reenabling the gpus in the device manager, they just come up code 43 and won't start.
I tried xoc_7c and get driver crashes when trying to overclock slightly with or without sli enabled. I am starting to think Win 10 is the issues, or maybe even the drivers possibly.
I was just wondering if you may have any insight, and I am going to back date drivers as well as try xoc-6c again.
Old 07-24-2016, 07:12 AM
Shadyreaper
I just wanna say Thanks Vince (Kingpin) I was able to use your xoc6C bios to push me past the 1518mhz barrier I have been stuck at (on air) at 1st it didnt work and my card would crash and stuff so I put the xoc7C bios on it didnt really help much so I decided to try the 6C bios again well Ill tell you what I was able to break that 1518mhz barrier and get to 1577mhz so far thank you and Tin for pushing the limits for everyone
Last edited by Shadyreaper; 07-24-2016 at 12:02 PM. Reason: added 3dmark scores from 1577mhz runs
