Old 12-18-2014, 01:42 PM
splmann splmann is offline
Hi vince ,
why is memory locked @ 7000 ?
Old 12-18-2014, 02:47 PM
perfect timing
Old 12-18-2014, 03:02 PM
l0ud_sil3nc3's Avatar
l0ud_sil3nc3 l0ud_sil3nc3 is offline
Originally Posted by Gunslinger View Post
perfect timing
Agreed, flash tonight and test.
Old 12-18-2014, 08:26 PM
Please make sure you are using the latest precision and NOT afterburner or any other utility. Newer versions of precision enable handle kboost differently, when using other sw it can cause conflicts with driver/OS.
I retested again with a fresh retail card and everything working perfectly when kboost properly enabled.
Old 12-18-2014, 08:43 PM
link?
Was having issues with memory locked when using AB as well, so this is good to know
Old 12-18-2014, 08:47 PM
I just added an internal version I am using to my last post with bios and evbot fw....EVERYTHING works 100% with classXX bios and this version precision if u do like I said. Don't use any other SW out there to XOC our cards, use what I have posted.
Memory can be adjusted anywhere u want ln2/air/whatever, no need for fixed clocks
Old 12-18-2014, 10:59 PM
hey guys its all fixed finally we can enjoy the unlocked mem slider and working K-Boost ETC most importantly the efficiency is back. :thumb:
Seems right where it should be!
To take advantage of the new bios and force P0 follow the steps below exactly.
1.Flash this bios
2.Delete AB or any other software you have that changes GPU clocks completely. (fresh OS maybe best but should be fine still)
3.Install THIS Precision X
4.If you are running SLI disable it
5.Open Precsion and enable K-Boost
6.If you are running SLI Enable it
7.???
8.Profit
Dont worry about GPU-z mem speed, eVGA just chose to divide by 2 not 4 like other companies.
Also if you didnt know already (I didnt)
You can control all cards on the evbot in 2 or 3 clicks. Connect cables to all cards. Then from the main screen load your profile and it will set to all cards. Also if changing options one at a time, choosing VGA 0 will set the options you are choosing to each card at once as well.
Here is the latest firmware confirmed working.
Right click save as.
http://overclockingpin.com/classfied980tools/980i43.hex
http://overclockingpin.com/classfied...tFlashTool.exe
Cheers! locked mem no need
Old 12-18-2014, 11:05 PM
^New bios working extremely well, great job EVGA
All air cooled for now. . .
Old 12-19-2014, 01:25 AM
small update all @ air
Old 12-19-2014, 07:28 AM
awesome stuff gents
