Old 09-24-2014, 12:02 PM
StrategosSan's Avatar
StrategosSan StrategosSan is offline
Thank you TiN, your sharing is great for the community.
Old 09-25-2014, 07:44 AM
slapmehard slapmehard is offline
I did not want ref card since I wont put an assend on it but jeez looks like so much fun.
Thanks once again for the info Tin I really love how you put up with us
Old 09-27-2014, 02:31 AM
rsannino rsannino is offline
Send a message via MSN to rsannino Send a message via Skype™ to rsannino
Thanks for sharing this guide.
Old 10-07-2014, 05:21 AM
**dp** **dp** is offline
hmmm.. my card burned up..
what did I do wrong?
EDIT: Tin - vcore readout.. could you show me?
I only did vcore + limiter.
Old 10-08-2014, 06:07 AM
You did the mod without knowing the read point bro?
try the spot In red on the inductor(or the other side of it) there may be a spot on the back but I don't have the ref card to see it myself
Well I hope someone can help you fix that...
I know there is no help for this card there to thin I tell ya
Old 10-08-2014, 02:44 PM
I tried on another card. Shunt mod works like a charm.. the vmod does not. Iam running the vcore mod only. card dies ASAP after modding... uncool.
Old 11-13-2014, 03:05 PM
lkozarov lkozarov is offline
Hi
Is it hardware mod necessary for power limit? Can I make VCore mod and use BIOS mod for power limit, instead of hard mod?
Old 11-13-2014, 09:57 PM
You can sure bypass power limit by BIOS.
And no, I don't have BIOS without power limit available, no need ask for it.
Old 11-24-2014, 06:32 AM
finas finas is offline
Guys,
I would like a clean solution to increase vcore and vmem by only a small amount on my reference GTX980 card, say something like 0.1v on memory and 0.05 to 0.1v on vcore. What resistance would I need for this ?
My card does 1557MHZ@1.218v with a custom bios I made with power limits removed. Anything more and I start seeing artifacts and driver crashes. I would like to reach 1600MHZ or a bit more, nothing fancy.
Memory is doing 4000MHZ and so I would like to push it a bit more too.
I also have another question, this time related to furmark: Has anyone tried to run furmark with TDP removed for more than a couple of minutes with an overclocked GTX 980 ? I had to increase TDP limit to 400W in bios for furmark to not throotle and I'm unsure if the power circuitry on the reference card can stand that much power draw without burning.
Thanks!!!!
Old 11-24-2014, 09:51 PM
You can try with 100 ohms VR set to max, adjust slowly till you get your +0.1V and then remove resistor, measure it with DMM, and solder fixed resistor of that value (for example you measure 28 ohm, so you can pop 27 or 30 ohms 0603 SMD resistor to card). It will be way more stable and less risk borking card by accident.
Why would you want to test furmark on reference card ? I would not feel safe doing that on reference card
evga, ln2, mad engineers, maxwell, modding guide, oc, trim pot
