Old 01-15-2014, 01:50 AM
Default EVGA GTX 780Ti CLASSIFIED KPE tools
XOC BIOS FLASH UPDATED 6/18/2015
http://overclockingpin.com/780kpti_t...tikp_xoc2C.rom
XOC BIOS(most current)
NVFLASH FILES for flashing KP XOC BIOS
(use this nvflash only in windows 64/32 depending on OS)(shift + right click in folder window after unpack and select open command window here and (if using 64bit) type nvflash64 980kp_xoc6C.rom then y then YES. If 32bit, use nvflash32 in command line.
http://overclockingpin.com/KP980%20x...s/CNVFLASH.zip
CLASSIFIED V CONTROLLER (rename the file extension to ".exe" after download)
http://overclockingpin.com/KP980%20x...ssified21._exe
EVGA PRECISION X 5335
http://overclockingpin.com/KP980%20x...p_v5.3.3.5.zip
EVBOT
Plug evbot into card turn on and flash this firmware in windows, follow any instructions given.
http://overclockingpin.com/KPti/780i31.zip
BIOS (dated)
Place nvflash, cwsdpmi, and bios image to bootable thumb drive and flash this bios in DOS to the LN2 switch on the card, be sure to power off once after flash and let the card re-initialize.
Flash Command:
nvflash -4 -5 -6 XOCKPti.com
When promted type in YES or y accordingly.
http://overclockingpin.com/KPti/XOCKPti.rom
http://overclockingpin.com/KPti/nvflash.exe
http://overclockingpin.com/KPti/CWSDPMI.EXE
This bios will ONLY work on KPE card, so don't bork your regular classified by trying to flash them to it . The cards are very different.
Don't forget to use really good aircooling on the pwm plate when pushing it over air/water cooling clocks and volts, it will get hot.
Enjoy the card, a lot of testing and work went into it
Old 01-15-2014, 03:52 AM
Doug2507 Doug2507 is offline
Thanks Vince, really looking forward to having a play with these!
Old 01-15-2014, 09:48 AM
Mack4033 Mack4033 is offline
So Vince if I can't your new card s from EVGA is the 780Ti Classified a good back up card to get? I plan to use the cards for hard core gaming ,benching water cooling only. I am stepping up from the GTX 680 Classified w/ Evbot. I have two of them with a custom bios
Thanks,
Mack4033
Old 01-15-2014, 02:42 PM
skyn3t's Avatar
skyn3t skyn3t is offline
What is the compression on the 780i31_zip? It has no extension and some how we cannot extract the file?
Thanks for the heads up. Thread at ocn is up .
Old 01-15-2014, 07:07 PM
I used 7zip and did "open archive" and I was able to extract the files.
Old 01-15-2014, 07:18 PM
woops
Ok, fixed the link. Let me know if issues.
Old 01-15-2014, 11:28 PM
skyn3t's Avatar
Originally Posted by k|ngp|n View Post
woops
Thanks all good now.
Old 01-16-2014, 03:11 PM
Philly_boy's Avatar
Philly_boy Philly_boy is offline
Send a message via AIM to Philly_boy Send a message via MSN to Philly_boy Send a message via Yahoo to Philly_boy Send a message via Skype™ to Philly_boy
Some of the folks at OCN are having difficulty flashing the bios. It isn't recognized during the flashing process when using NVFlash. One guy got it to flash but it lengthens his boot up/shut down times to 3+ minutes LINK
Can anyone help?
The Broad Street Bully
| Gigabyte Z87X-OC | 4770K | GTX 780Ti Classified | Corsair Dom Platinums |
| Samsung 840 Pro SSD | | AX 1200i + PC P&C Turbo 1200 SR |
you guys are the best But im vinboe's bytch
Old 01-16-2014, 04:33 PM
Dancop Dancop is offline
As he said!!! Not for regular classified!!!
Old 01-16-2014, 08:20 PM
Q56_Monster's Avatar
Q56_Monster Q56_Monster is offline
OCN guys must have a Tardis. ..stole a card from the future, brought it back. Or, they just can't read.
