Go Back   kingpincooling.com > The Lounge > Members Rides
Members Rides Brag about your actual ride or your daily pc rig.
Old 08-08-2010, 07:08 PM
now building some more Coolit in the case :
news toys in the house :
Everu TEC cooling from coolit needs to go INSIDE the Thermaltake Level 10 case :
primer :
Old 08-08-2010, 07:09 PM
Freezone Elite and the Boreas Chiller are ready with paint, only sleeving needs to be done :
The Boreas Chiller, and how it's going to be mounted on the Level10 case :
[youtube]http://www.youtube.com/watch?v=tg4mQPt8K-E[/youtube]
Boreas Against the case instead of the HDD trays, while Freezone and Freezone Elite gets in the motherboard box :
Take the form of the HDD trays with vertical lines and air trap, i will use red smoke acryl :
Old 08-08-2010, 07:10 PM
De Boreas Cooler is almost ready, only two more mods on it, and then it can be mounted on the case :
Een Classified plate bent, the temp sensor getted a black 3pin plug and instead of sticky tape it has now a heatpad between it :
De fan cables are black on the fan, and from the fan in red sleeving :
De Coolit Freezone has 2 broke TEC modules, have to change them with new onces, and then the red blocks can be mounted on the cooler :
the spray corner where i painted the blocks :
change every bold and nut on hole the pc, also the coolers
little mod for the boreas and freezone elite chiller's
only the blue neon has to be change in red neon, they are ordered :
http://www.youtube.com/watch?v=W472AlaLsbA
Old 08-08-2010, 07:12 PM
de Coolit Boreas MTEC Chiller has his place against the case now, a little lower because above the boreas a koolance tms-200 with expansion board will come,
also modded. only making a mat black acrylaat for finishing the hdd bays holes for between the boreas and the case.
And painting the mounting for the boreas also black.
today only change the power for the led's in the Corsair HX1000 psu what i made see tru,
and put the first led's in the 5mm fan shroud for the boreas chiller :
PSU
De Boreas Chiller :
Old 08-09-2010, 03:43 AM
miahallen's Avatar
miahallen miahallen is offline
Great work Chiller....now lets see the numbers
The post counter is not an intelligence meter!
Gautam: "I remember when Mark started doing DI I thought he was psycho and that it was a dangerous, reckless cooling method that had no future."
Heat Team IRONMODS
Old 08-09-2010, 03:56 AM
Nice modding, but TECs are useless
Old 08-09-2010, 06:07 AM
with numbers ???
Why useless ?
For 24/7 it's nice i think, cooling below ambient room temp.
For benching it's nothing, then better Dice or ln2.
Old 08-09-2010, 08:11 AM
nigel's Avatar
nigel nigel is offline
Send a message via MSN to nigel
i just like it ^^ tec's are just fun ^^ (wel its in my eye's )
http://nigelpoint.blogspot.com/
The duck is here together with the Frozen Duck
Old 08-09-2010, 08:20 AM
i find it also fun for in a 24/7 rig.
cools just that little more then watercooling, and if you have 24 TEC plates,
then it cools just fine for a nice 24/7 OC.
