Old 01-17-2014, 11:03 AM
Deaf Jam Deaf Jam is offline
Originally Posted by FTW12345 View Post
Update with fix for 4 cards by slightly adjust UI.
also support higher PWM frequency.
For me 400Khz is running fine, not sure any help from higher frequency
http://www41.zippyshare.com/v/28849623/file.html
Thanks. It helped a little. My classy is now stable at 1.33 instead of 1.356 at 1306 MHz under water. I just need to decide whether I want to buy the Kingpin seeing or run my dud classy into the ground.
Old 01-17-2014, 04:58 PM
machineghost7 machineghost7 is offline
Thanks so much
Old 01-30-2014, 03:24 PM
VSG VSG is offline
FTW, the classy tool doesn't work properly with the Kingpin cards. We only see a max core slider of 1.35 V and a DMM reported the actual voltage to be 1.31 V instead. Any chance you have a fix in mind? Thanks for everything!
Old 02-05-2014, 01:54 AM
FTW12345 FTW12345 is offline
Hi,
hmm, i've added the maximum to higher, please give it a try.
http://www7.zippyshare.com/v/64361314/file.html
seems this card has more potential than regular classy
Old 02-05-2014, 06:28 PM
VSG VSG is offline
Awwwwwww yeah
Cheers man, I am still setting up my loop but I will let the guys on OCN know so they can give feedback sooner than I.
Old 03-14-2014, 09:27 AM
VSG VSG is offline
lol I just realized I never gave any feedback on this. It works great on the KPE- maxes out at 1.65v applied (and even higher under load).
Even thought the slider goes up to 1.65v for both the 780 Ti classifieds- regular and KPE- the regular classy does not get anymore than 1.5V applied even under LN2. I do not know if this was intentional or a bug. Cheers, man!
Old 10-26-2014, 09:18 PM
Hi All,
Recently I'm cowork with Kingpin on the new release board ( should be GTX980 classy? ), seems the test result is decent.
http://www15.zippyshare.com/v/13137163/file.html
Let me know what's your thought on this and if can share any test result when you get this board.
Old 10-31-2014, 10:18 AM
VSG VSG is offline
Awesome work, thanks again
I'll pass on the link.
Old 02-20-2015, 05:12 AM
tyvar1's Avatar
tyvar1 tyvar1 is offline
Send a message via Skype™ to tyvar1
Will you update this for the new GTX 980 KPE?
Intel i7 4790K @ 4.8GHz | NZXT Kraken X61 | EVGA GeForce GTX 980 Classified K|NGP|N Edition @ 1500/2000MHz | Samsung SSD 850 PRO 256GB | Asus Z97 Deluxe | Corsair Carbide Air 540 | Eizo EV2736W IPS & BenQ XL2420G 144hz G-SYNC | Corsair Dominator Platinum 1866MHz 16GB (4x4GB) | Seasonic Platinum 860W XP2 | Asus Xonar Essence STX |
Old 02-23-2015, 03:06 PM
Hi All,
hey man thanks a lot for all your hard work with the classified's, definitely made it a better experience for us.
Is it possible to update the tool for the new 980 Kingpin. Currently evbot is only way.
