Old 11-20-2010, 01:53 PM
Cyph3r_Smurf Cyph3r_Smurf is offline
How much info would you need to help me with making a 5770 ref to a zombie ? (The GPU is toasted)
Then I could you it for practice and an example.
Old 11-20-2010, 01:57 PM
Hi-res photos of card both sides, VRM area hi-res photo. Thats all
For photos storage you can use my private ftp (xdevs.com) with login and pass - "guess" w/o ticks.
Old 11-21-2010, 05:50 PM
Quake's Avatar
Quake Quake is offline
Send a message via MSN to Quake
And what about GTX 260 Lightning?
Mod request #0003
* MSI Lightning GTX 260
* uP6208 for GPU - datasheet and can't read what is for memory as it is too damn tiny
* External voltage regulation - I want to try connect this voltage regulation on X1950XTX or 7900GS for beginning
* Card isn't working, I think some memory chip is bad... What do I need to create this
Old 11-22-2010, 11:01 AM
So many people want zombies, i wonder why? Because this look insane? Hooking zombie-power is not as simple as hooking VR to stock VRM, it needs heavy soldering lot of wires and 100% forget about RMA or anything stuff. And if this all done badly - no gains, in worst cases it will just smoke both vga and motherboard. So it's worth only for LN2 ultimate runs
Old 11-22-2010, 11:22 AM
Quake's Avatar
Ofcourse no rma and only LN2... There is no rule that this will help cards clock better, but that is why we are here to find out and learn new stuff
Old 11-26-2010, 02:53 PM
Okay, dear necromants. Lets go inside.
Stage 1a
First step : Take some dead motherboard and desolder PCI-Express graphics slot from it. You can use anything, even camp fire to get PCI-E slot from board. You need only slot with undamaged pins.
Do that, and report back to move further.
Old 11-27-2010, 07:41 AM
Quake's Avatar
Can we use PCI-E extender? if yes, I'm ready for next step
Old 11-27-2010, 06:20 PM
Me too took a old dead asrock motherboard to 300 degrees in the oven today.
Old 11-28-2010, 05:42 AM
Stage 1b
Ok, now make adapter for standalone videocard powerup
I did it like this
Detailed guide on link above.
Old 11-28-2010, 04:17 PM
I'll make this this weekend and upload pictures
mad engineers, overclocking solder guys, zombie
