  #441
Old 07-18-2016, 08:08 PM
Yes, you are hovering with nice speeds there, I'd be happy to leave it as is. Even if you spend lots of effort and risk (e.g. chilled loop) to get magical 1600MHz, it would not be stable everywhere at max perf.
You can try memory at 1.7V-1.725V, perhaps you'll get hundred meg or so from that, for what it's worth
Old 07-19-2016, 11:16 AM
Mave74
Hey TiN, thanks for the help, really appreciate your effort to help me. Im going to do following: Set the card to 1.15 Volt set it to a unstable clock and raise the voltage where the clock gets stable so I get the best clock and voltage? And with the memory I will just add a 400K resistor to the mem voltage controller, I have the datasheet no help needed there...
Also I really like yo Kingpin cards, I haven't ever owned any EVGA card but they seem like a great deal for overclockers, especially the one mentioned above!
Old 07-19-2016, 12:34 PM
Mave74
By the way, what is the LAST voltage slider for in the Maxwell BIOS editor rev2?
Screen: https://gyazo.com/aac2a6fd945f0fbde2a8078406d0deb4
Old 05-28-2017, 08:26 AM
DR4G00N's Avatar
DR4G00N DR4G00N is offline
Not sure if this is the exact right place to ask this.
But do you know how to get Westmere core Xeons working in the X58 SLI LE Rev. 1.0 (E757)?
I did the mods from this thread: http://forum.kingpincooling.com/showthread.php?t=2780
but no dice, get's an instant FF post code with my X5650, X5670 or X5687. My L5520 & E5540 work fine in it now though.
Old 05-28-2017, 08:27 AM
DR4G00N's Avatar
Edit: Nevermind, I figured out it needs the same mod as the E758 so I got it up and running now.
