Old 08-03-2010, 01:53 AM
dinos22's Avatar
dinos22 dinos22 is offline
woot i win lol
seriously what is it that you are building.........we are all intrigued
Team.AU
Got tube?
GIGABYTE Australia
Need a GIGABYTE bios?
Old 08-03-2010, 02:02 AM
To make guess easier, i give you all a hint:
These are main chips (except ATMEL MCU will be in another package) which this product will use. Google what these chips can do and make the total idea what is product about.
I'm waiting!
Maybe most smart man will get free result of product operation
Ah, and one more hint:
Product will need powerful cooling. Most powerful from available for small money. Even full boiling Kingpincooling.com Venom pot can't handle such loat at once
So, i will use six to eight extremely powerful and loud 120x120x50mm finger-killer fans.
See, two awesome hints!
Old 08-03-2010, 02:48 AM
dinos22's Avatar
some kind of temperature control unit?
Team.AU
Got tube?
GIGABYTE Australia
Old 08-03-2010, 03:12 AM
Nope, wrong direction.
Old 08-03-2010, 03:33 AM
T_M T_M is offline
EVGA Touchable
Old 08-03-2010, 03:57 AM
G H Z's Avatar
G H Z G H Z is offline
sb cant touch this
OK it's not for cards, it could be for RAM but I think it's really to power the CPU itself. ADE7755 will monitor output's and there will be a software UI so we can happily do what we must to a CPU
Old 08-03-2010, 04:01 AM
BenchZowner's Avatar
BenchZowner BenchZowner is offline
Being a good boy :)
Digital voltage controller with multiple outputs.
Considering the circuit complexity and the IC count you mentioned I'd bet that it doesn't stop there.
OCP / OVP indicators.
Voltage monitoring ?
Switching frequency control for VID/Resistor network controllable PWM contr. ?
Digital VID control ?
Old 08-03-2010, 04:09 AM
thebluemeanie1 thebluemeanie1 is offline
Ln2 pot load tester? Seems to fit the hints.
Old 08-03-2010, 04:39 AM
thebluemeanie1
huh, what? If this is for ln2 pot testing, what for 6-8 high-cfm fans ? :-D No.
BenchZowner
Nice try, but push more. Wrong direction.
There are NO inductors onboard.
Huh what? pwm controllers usually are placed in one small IC, not big 245 x 140mm board with 4 layes, aren't they
Your variants are too simple man. Raise the complexity.
One last hint. This device don't require operator attention for long time. Just set, fire it up, and go for coffee. It's automated.
And not related to LN. And ADE7755 chip is not usual A/D convertor.
Old 08-03-2010, 04:45 AM
Massman's Avatar
Massman Massman is offline
Send a message via MSN to Massman
Is it ... the end of human overclocking?
Some kind of device that tests the overclocking capabilities of CPU/VGA. Set voltage/frequency, test, get feedback and adjust v/mhz accordingly?
