Old 04-25-2010, 12:51 AM
ghost_recon88's Avatar
ghost_recon88 ghost_recon88 is offline
I wonder is it possible to flash a P6X58D Premium to a R3E?
Old 04-25-2010, 01:21 AM
No. I've tried with P6T to R3E. They have too much different design.
Old 04-25-2010, 01:43 AM
George_o/c's Avatar
George_o/c George_o/c is offline
How did I miss that?
Congratulations Tin, you are amazing my friend!
Old 04-25-2010, 02:25 PM
Does the P6X5D Premium BIOS have the "CPU Turbo Power limit" override option, as seen in the P6TWS Pro BIOS?
Old 04-25-2010, 02:31 PM
P6X58D dont have it
only WS
Old 04-25-2010, 03:24 PM
So for 2D benching on the P6T Dlx, you would recommend flashing to the P6TWS Pro BIOS?
Old 04-25-2010, 03:27 PM
i guess for 3d also.
Old 04-06-2013, 10:52 AM
Ronn3y Ronn3y is offline
Default P6T -> P6T DLX?
Is it possible to cross-flash a normal P6T (no SE no DLX) to a P6T DLX? The boards do seem very similar.
Especially since the DLX version allows you to change the PCIe speeds (either 16/16/4 or 16/8/8) which is exactly what I need.
Old 04-07-2013, 12:15 AM
Try it and report
Old 04-07-2013, 04:29 AM
I am tempted, however I do not own a BIOS programmer... If someone confirms having done this succesfully I'll probably have a go at it.
I've been looking online for a BIOS programmer, but I found that most of them you need to built yourself. Which is not really suiting for me... If I would have I programmer, I definitely would try it out.
cross-flashing, killing hardware, mad engineer
