Old 03-03-2010, 08:30 AM
Originally Posted by Oj0 View Post
It has no way of interfacing with the CPU so I'm not quite seeing how this will change anything, hints please
What TiN is showing here is not really what I am referring too, though this is pretty neat for F1 pots.
Lets give it some time to develop and then you will know what I mean by game changing
Old 03-03-2010, 08:49 AM
knopflerbruce's Avatar
knopflerbruce knopflerbruce is offline
Some weird kind of anti-CB/CBB device?
bobo, the 5870 lightning you shot, did you save the stock cooler ?
Old 03-03-2010, 08:58 AM
Oj0's Avatar
Oj0 Oj0 is offline
OFFHAND it doesn't look as if there's any interfacing of any kind so it appears to be a standalone device.
REAL NAME JONATHAN
ROCKING, ER, CLOCKING IT OLD SKOOL
Allright, maybe this device can override the OCP on the new i5/i7 chips?
Old 03-03-2010, 09:01 AM
Oj0's Avatar
Oj0 Oj0 is offline
I still want to know why my question about in or under was ignored
REAL NAME JONATHAN
Old 03-03-2010, 09:04 AM
Sam__'s Avatar
Sam__ Sam__ is offline
But it does seem to the the right dimensions to fit between the pot and the cpu. :S
theres at least one 8-pin ic on it. Looks like there could be a few connections for external control.
this is very confusing.
Old 03-03-2010, 09:07 AM
Oj0's Avatar
Oj0 Oj0 is offline
It's so hella confusing I'm calling Hella
It's going to:
Worsen contact, poorer thermal transfer
Get crushed to death
if it goes between pot and chip. However, the dimensions seem to be the same as inside a pot as well.
REAL NAME JONATHAN
Old 03-03-2010, 09:09 AM
...because the placement is under the board, so it CAN interface with the CPU That's why the hole is there for, I bet... so it won't interfere with the stuff right under the chip.
Old 03-03-2010, 09:12 AM
Oj0's Avatar
Oj0 Oj0 is offline
That hole is too small, the entire thing is 45mm across so the hole is about 9mm
REAL NAME JONATHAN
Old 03-03-2010, 09:17 AM
Sam__'s Avatar
So it might go inside the pot, but what could it do there? warm it up quickly? but people have already had the nono on it being a cb/cbb device.
