Old 10-03-2010, 06:47 AM
Massman, YGPM
Old 10-09-2010, 01:24 AM
http://slipatch.com/download/ - patch download page
Latest SLI patch tool. Working and designed for every drivers, including latest 258 and 260 drivers.
Automatically detects OS type, and applies necessary mods.
Old 10-09-2010, 10:27 AM
Eiswolf93 Eiswolf93 is offline
hey guys,
i thinking a long time about SLI with 2 x 7950 GX2 on X58/P55.
Do you think it is possible?
new 18x.xx driver doesn't support sli with 7950 GX2 and older drivers won't work on X58/P55.
Have you a solution?
Sry for my noob english
Old 11-24-2010, 12:19 PM
RagingCain RagingCain is offline
Send a message via Skype™ to RagingCain
Okay who do I have to blow, to get some GTX 580 SLi support
Seriously though, anybody need some specifics or a vBIOS dump or something?
ASUS Crosshair IV Extreme (BIOS 0502)
2x PNY Geforce GTX 580 XLR8 Edition (SLi)
P.S. I know I have Lucid HydraLogix (no support either for the 580 yet.)
Old 11-24-2010, 12:28 PM
Ain't SLI working with latest SLIpatch 0.9b ?
Old 11-24-2010, 12:34 PM
That is correct. What would you like me to try?
Followed instructions to the letter.
Got two choices for dual-booting, one obviously SLI-Patch modified.
Still no go for SLi, also believe we have had success with other cards on this board, I am coming here from Overclock.net (we have had some issues with latest drivers.)
Unfortunately, I need the latest drivers, because of the newer card (580.)
I am at work right now, but any info you need or want (if you are still interested in maintaining your clever little patcher) is yours, when I get home.
Operating system is Windows 7 Ulti (x64).
Forceware Drivers 263.09
Old 11-24-2010, 12:41 PM
Can you try with older cards (just any two paired cards for SLI) on this motherboard in same slots?
I'm not sure if Hydra is not messing stuff down. I do not run AMD systems since S939, nor dont have 580's, so can't confirm your issues altogether.
Old 11-24-2010, 12:47 PM
I don't have any other nVidia cards, just switched from Trifire 5870s.
No pressure on you, I will get support from HydraLogix eventually.
Just at least wanted to bring it up.
I read all the Q&A on site. Thats where I got the idea to switch slots.
I initially had the 580 in PCI-E slot #1 (Northbridge 890FX controlled) and
PCI-E slot #5 (Southbridge 850 / LucidHydraLogix controlled.)
Then I tried (after a clean install of everything) PCI-E Slot #1 (Northbridge 890FX)
and PCI-E Slot #3 (Northbridge 890FX.) So I have essentially eliminated almost
all interference from Lucid being silly.
I do plan on doing a fresh Windows 7 install, now that I have moved the cards
around etc. I will try again, but I am fairly confident I did it right. You never know
though with Windows
Dynamo Kiev!
//EDIT
Tried a full fresh install of Windows 7, no dice. Report of another user at the
TechPowerUp site, not being able to get it work for 580s either.
Also tried the very first set of drivers to support the 580, the 260.99. Didn't
work with that either Oh, well, going to enjoy the one card for now I will
check back periodically, I see that you posted this in your free time, so just a thanks
(even though I have never used it before) for all the cool stuff has done.
Old 01-05-2011, 10:53 AM
Negcreep Negcreep is offline
Hi there, I have SLI GTX470's and have been using the SLI patch in win764bit for some time now using 250/260 drivers.
However I cant seem to get the patch working with 265.90 (quadro) and 266.35 (beta) drivers. I think the 266.35 one is meant for the 500 series but I have installed this type of driver previously (262/263) and the patch worked fine.
Bit worried I wont be able to keep the drivers up to date and SLI enabled soon. The 266 driver fixes some SLI GPU utilisation issues with games like BC2 , which Ive been waiting for a while now. Currently I cant use it due to lack of SLI.
Is this a beta driver issue or a new incompatibility with the latest drivers? Do you think they will fix it?
*currently im using 260.99 and it works fine with the SLI patch. As soon as a higher version goes on , the nvidia control panel will crash when I enable SLI.
Old 01-17-2011, 04:20 PM
PP Mguire's Avatar
PP Mguire PP Mguire is offline
Send a message via AIM to PP Mguire Send a message via MSN to PP Mguire
Trying 1.0 with a P55 UD3R and 2 465s. No luck so far with the 260.99 drivers so I'm downloading the Beta right now.
nvidia pwned, overclocker heaven, reverse engineer, sli hack
