Old 09-24-2010, 06:52 AM
For quad-sli with 4 singlecore vgas drivers need to see nf200 bridges. It's very hard to emulate them via software I guess. And I see no much need in that, if somebody can afford four top cards for $$$ then 400$ for proper max-speed board is not so a deal afaik.
So it's not couple of lines, we even dont know what exactly nf200 do, except PCI-E switch.
Old 09-24-2010, 07:09 AM
resident1509 resident1509 is offline
Awesome, stealing intellectual property is cool!
Old 09-24-2010, 07:53 AM
patch authords modified few bytes for own personal use w/o any warranty, I think.
Old 09-24-2010, 01:11 PM
FatAlbert FatAlbert is offline
Send a message via Skype™ to FatAlbert
you guys are thieves ! :
/sarcasm off
well, I ask 'coz not every bencher use intel
but at least triple sli works without problem
no cash Venom Lover <3
I don't write posts because I have nothing to say when you are extreme I am a noob without good hardware to extreme oc and only with dreams
Old 09-26-2010, 03:45 PM
DonQuichote DonQuichote is offline
Just coming form a german community where I read about this case.
You guys are awesome, bringing nvidia to code malicious software.
Go ahead bringing them to black despair until they start considering the customers needs.
Best greetings from Germany
Don
Old 10-02-2010, 03:56 PM
Massman's Avatar
Massman Massman is offline
Send a message via MSN to Massman
Since X58 supports 3-Way SLI by default, I suppose this patch would also enable 3-way on older chipsets?
Trying to get the patch working on this 590i board, but no luck so far. When trying to load the sli-enabled partition, I get the message that ntoskrnp.exe is corrupt.
Old 10-02-2010, 04:18 PM
Yes, of course.
But you need to ensure that all cards running same root PCI-E complex, from what i know.
Old 10-02-2010, 04:28 PM
Massman's Avatar
How to check for root PCI-E complex?
I suppose that even if SLI wouldn't work due to a different root complex, the OS should still be booting?
Old 10-02-2010, 04:31 PM
Yah, it should boot.
Try to clean up system back and apply everything exact as described in on slipatch.com site
Old 10-03-2010, 05:50 AM
Massman's Avatar
Looks like I just needed to use the 0.9 patch .
nvidia pwned, overclocker heaven, reverse engineer, sli hack
