Old 09-17-2014, 04:31 AM
Rsnubje's Avatar
Rsnubje Rsnubje is offline
Nice work! Too bad some components cost quite a bit.
Old 09-17-2014, 01:53 PM
mushy409's Avatar
mushy409 mushy409 is offline
Default Project complete! Now Repaired!
Finally some good results! Found a burnt out SMD resistor on the back of the card (100 ohm 0402) which was shorting one of the RAM data lines to GND
Also given the GPU a quick reflow with some Insat Super flux
Card is now recognized as a Radeon HD7900 Series. (I've underclocked & undervolted both RAM & GPU for now)
Overall, very pleased with the result! There's going to be more projects posted up once I've finished stressing this card
Old 09-18-2014, 03:50 PM
Rsnubje's Avatar
Sweet
Old 10-27-2014, 08:12 AM
Masterchief79 Masterchief79 is offline
What's up, did you get it working again?
Old 12-03-2014, 08:00 AM
mushy409's Avatar
Yes the card is working fine, even after a few hundred hours of gaming and benching. I've also flashed a HD7970 bios to the card
Got the Vcore at 1.3v and Vmem at 1.55v (bios edited)
Core @ 1375MHz
Mem @ 1550MHz
Can push the core even further with extra voltage but the temps are pretty high. I'm investing in a waterblock for the card to squeeze out the extra juice.
Memory is limited as its Hynix and won't go any higher even with extra voltage.
I've also glued some heatsinks to the VRM/MOSFETs which keeps them nice and cool @ 60*c under full load.
Core temp hits 68*c after a few hours of gaming. If I crank the fan to 100% it drops to below 60 but is too noisy for my liking.
All I've done instead is edit the PWM profile so the fan reacts faster to the core temp.
I've also raised the TDP limit to prevent the card from throttling.
Old 12-03-2014, 10:51 AM
basco basco is offline
thanks for sharing.
