  #31
Old 09-10-2015, 09:58 PM
Originally Posted by coolhand411 View Post
I'm not sure what the new XTU setting does ..I have tried all the settings at the same freq./timings and my score remains the same
when i tried it was only improving deproving on 2dimms but not 4 dimms.
Old 09-11-2015, 07:00 AM
Hazzan's Avatar
Hazzan Hazzan is offline
Send a message via MSN to Hazzan
from my experience better just leave Auto, I set with tight score prety low when I set on loose score much higher, that function only for 2 dimm not for 4 dimm
3733 working good on M8E ..more vdimm nothing help on MFR chipset best spot MFR I think lower than 3800
AOCC 2007 - AOCC 2008 - GOOC 2008 - MOA 2009 - MOA 2010
Old 09-13-2015, 01:36 AM
coolhand411's Avatar
coolhand411 coolhand411 is offline
Thank you Shammy ,Hazan !
Swapped PlastDip for Dragon Skin and finally got some results-good enough for #1 i5 /XTU ,not bad for random NewEgg sample ..this board is smooth,I'm loving it
Old 09-21-2015, 04:18 PM
Woomack Woomack is offline
Similar experience here. XTU option at auto gives better results than any manual setting. In some cases manual settings were the same as auto but never better.
Old 09-28-2015, 03:12 AM
Dum3 Dum3 is offline
xtu auto or 6 same values,you have to take care the variation of xtu score which is 10-15 points from lowest to highest...
eff with 4x4 afr is spot on,i think 1620 is doable need to tweak mooar
Old 12-20-2015, 11:00 AM
fredyama fredyama is offline
Testing G.Skill F4-4133C19D-8GTZ on M8I, M8G & M8E:
M8I:32M
M8G:32M
M8E:CBR15
Old 12-23-2015, 03:30 AM
Awesome as always fredyama-San thanks
Old 12-23-2015, 05:29 PM
Many thanks, Hiwa-san.
Wishing you Happy Holidays and a New Benching Year!!
Old 01-12-2016, 01:22 PM
GGI78 GGI78 is offline
The bios for M8E is not availlable or the link is corrupted
Old 01-15-2016, 06:38 PM
B-die / new bios
