Old 09-01-2015, 06:23 AM
I keep trying to update to 0004 using the flashback method, but when it's done it says 0402 x64 in bios.
Old 09-01-2015, 11:59 AM
Gunny you're prolly using the wrong usb port, the one in one guide is wrong, Meshter TL posted the right pic in his thread.
Old 09-02-2015, 04:48 AM
Hazzan's Avatar
Hazzan Hazzan is offline
Send a message via MSN to Hazzan
board strong enough...next run will trying 3400 4dimm
AOCC 2007 - AOCC 2008 - GOOC 2008 - MOA 2009 - MOA 2010
Old 09-02-2015, 07:15 AM
I'm using the USB port directly below the lan cable port. The light on the flash back button is blinking and so is the light on my flash drive when it is "flashing"
It still comes up as 0402 though.
Old 09-06-2015, 09:28 AM
coolhand411's Avatar
coolhand411 coolhand411 is offline
tested Hot mfr on cold last night and was maxing out 16gb c11-15-15-28/tight @3500+
Samsung 8gb /air
all air ,Quad Jaws @3733
Old 09-08-2015, 03:30 AM
FlanK3r's Avatar
FlanK3r FlanK3r is offline
Send a message via ICQ to FlanK3r
this is aweesome, I need my CPU back from RMA :-/ (14 days today at RMA process)
AMD Athlon 3000+, Athlon 3200+, X2 4600+ EE, Athlon 5150 (Kabini), Athlon 860K (Kaveri), AMD Phenom II x2 550 BE,2x PII x4 965 BE, PII 970 BE, PII 975 BE, PII 980 BE, 1090T BE, 1100T BE, AMD A8-3850, A8-3870K, 5600K, 5800K, 6800K, 7850K, FX-8150, FX-8120,FX-4300, FX-6300 FX-8300, FX-8320, FX-8350, FX-8370E, FX-8370, FX-9370, FX-9590. Intel core i7 2600K,core i7-3770K, core i7-4770K, i7 980x, Intel core i7-3930K, i7-5960X
Old 09-08-2015, 06:10 AM
fredyama fredyama is offline
WinXP works fine with Bios 0004 8/26
Old 09-08-2015, 07:32 AM
looking good as always Fredyama-san !,time for XP
EDIT; some cold mfr (fast W7 /32M ..I think )
Old 09-09-2015, 06:55 AM
Do I dare try to flash it through the normal bios method? I've tried every USB port but it still comes up 0402
Old 09-09-2015, 08:37 AM
I was having same problem,end up flashing via bios (no problem so far ),..the only issue I have is my CPU-Z that shows Core VID instead of Core voltage but this might be related to CPU-Z ..
