Old 02-21-2015, 06:32 PM
Claviger Claviger is offline
Thanks all who have posted the Matrix stuff. Got my initial run done with LN2 Mode enabled of a few benches, watercooled using the Bitspower block. Here is the first:
http://www.3dmark.com/3dm/6047032
http://www.catzilla.com/showresult?l...sult%20Details
1.425 vcore (measured at point)
1.71 vmem (measured at point)
1566 core
8400 mem
Temps were acceptable:
53c gpu
58c vrms (measured with a probe inserted by the vrms)
Any suggestions on where to stop on vcore since temps are under control? Thinking for longevity, this is about the stopping point for the vcore.
Old 03-04-2015, 12:11 AM
Hiwa or anyone else who has tried both origina l and fixed Mem bios.
Did you see any difference is headroom or voltages required for cetain clocks between the two?
Old 03-06-2015, 07:43 AM
i switched directly to fixed memory
Old 08-02-2015, 08:55 PM
coolhand411's Avatar
coolhand411 coolhand411 is offline
when I'm booting with LN2 bios (from first page) the splash screen will hang momentarily and screen resolution sometimes is set to 800x600 ,the biggest problem is GPUTweak -it won't open ,I 'm getting "Fail to load dlls.Please install VGA driver " if I boot with normal LN2 bios everything works fine ,I have tried z97 and x99 with no avail ,any help guys ?
EDIT; this is in Win7 and Win10 (clean installs )
Old 08-03-2015, 10:12 AM
Sometimes a very different BIOS will require a fresh driver install. Boot with the BIOS you intend to use and reinstall driver.
Old 08-03-2015, 05:21 PM
wiped all the drivers (driver sweeper ) and GPUTweak -it..still no joy ,Thanks for your help player
Old 08-03-2015, 10:46 PM
Ah shoot. Sorry Mr. Luke
