Old 12-18-2014, 08:39 AM
Default Matrix GTX 980 Tips
Originally Posted by coolice View Post
Quick Matrix GTX 980 Tips :
Try your card on air to see max Memory Frquency then Flash the Bios mine is M980_87.rom
1. Black Screen at -90 with DVI use HDMI ( -120 OK)
2. Apply Voltages and Frequencies at -95 otherwise Artifacts and memory Problem
3. Torch your pot at -80
4. Easy benching at -140
5. Problem when comes in IDLE( when benchmark finishes) sometimes you need to warm up till -70.
6. tried 1.25 PLL , 1.75 Vmem and 1.6x Vgpu
7.HotWire works perfect
8.Matrix Controller Works Perfect
9.GPUtweak Works Perfect
10.Enable Memory Defroster always
Please share if you have more tips and if all these work also with you, i tested 1 card only.
Old 12-18-2014, 11:03 AM
nacho_arroyo nacho_arroyo is offline
Good info, thanks for share it man!
Old 12-18-2014, 04:26 PM
Good idea for a thread Hiwa! I'll be freezing mine soon.
Old 12-18-2014, 07:33 PM
Dancop Dancop is offline
I froze mine today...
DEF not what I expected---maybe my bought one runs better
Old 12-20-2014, 10:10 AM
Good run Daniel, what are u expecting ?? arround 2.3GHz :O hahehehe
Good work!
Old 12-22-2014, 09:25 AM
mortisboy's Avatar
mortisboy mortisboy is offline
Very nice Hiwa, i'll test again mine with fixed bios to see if is any better.
Old 12-22-2014, 10:04 AM
Nice run Daniel
Would be nice if we add more info to each screen we post.
Old 12-23-2014, 07:24 AM
For instance, you described all the important things.
Just one more to add....start with low clocks like 2050 and then raise it in 25 Mhz steps - benching the card warm I say!
Old 01-19-2015, 03:18 AM
Dumo Dumo is offline
All above @ Hiwa's first post
No problem using dvi/vga adapter, memdefrost @ all time and gputweak works perfectly.
Testing bios M980_90.rom @ 1.6V+/1.68V/1.2V
Old 01-19-2015, 04:20 AM
nice ultra Dumo.
