Old 01-24-2014, 07:41 AM
bartx bartx is offline
Good, keep it going..
Try keep wires shorter, this is not so good now on your pics.
Also i'd keep 16V caps as that voltage plane my go some other parts, like memory PWM input or something.
And I'd shhrrr-shrrrr much more on motherboard to have wide and solid connection for power planes.
And don't forget grounds! You need keep same or more wire amount for ground return. Current flows from power to ground, it must be adequate to have all that power return back to VRM card, or you will have big problems
It's not so easy to make these wires shorter on this 8800 board. Too bad, that neither I nor Ivanov have a scope to test quality of power supply. Also the most important thing is to connect vsense from 8800 to back of the gpu/socket - it really makes huge difference in load stabiliy.
Old 01-24-2014, 09:37 AM
looks extremely clean dont you just hate where they put the 20 pin XD
Old 01-24-2014, 11:24 AM
but it is not so simple
Overclocking or altering hardware is nothing but simple, so no, that's not an excuse.
Why say so?
Well, motherboard have two sides. And guess what, even not having motherboard in hand, i can see on photos that original inductors were thru-hole DIP type. So big chance that you could solder epower/8800gtx vrm on bottom side of board, directly to power plane copper
They couldn't be bigger without making short circuit
Also can see big copper plane going to CPU socket. Is that not vcore plane?
If yes - there is plenty of available copper
Old 01-25-2014, 06:07 AM
ivanov's Avatar
ivanov ivanov is offline
I have a friend with oscilloscope. I will arrange measurements
I checked this plane directly under the socket and indeed it would be good.
But I wonder if benefits of shorting the electrical path would overcome benefits of better filtering.
When I solder to this plane under the CPU I will omit capacitors. Moreover the cables will be longer. And final thing - soldering planes on 8800 PWM will be still the same. And for now they are the same size as on the ASRock.
And don't forget about problems with insulating such thing with thick wires nearly directly under the socket :P
As for now I added two more GND cables. And I am choosing tantalum capacitors for the board.
Old 01-27-2014, 11:47 AM
George_o/c's Avatar
George_o/c George_o/c is offline
Nice one mate
Stelaras had a similar idea for these boards, let us know how it goes
Old 01-27-2014, 01:32 PM
ivanov's Avatar
This is how it looks now with two more GND cables.
And this is what I use to solder this thick wires.
It has 200W and I persume it was designed for soldering gutter. Tip is much bigger than my thumb xD
For size comparison my "regular use" 80W soldering iron.
I am waiting for capacitors. As soon as they arrive and I solder them I will post the results
Old 01-29-2014, 04:58 PM
ivanov's Avatar
Ok, some update.
I soldered new Panasonic 16V capacitors back to the place, where old 16V ones were.
Tried OCCT Linpack on E7200.
Results were so-so. Not so bad, but could be better.
V-drop was noticable both on software redout and on DMM.
V-core was kind a fluctuating a bit under load.
This is how vSense looked like (red wires soldered to SMD capacitor).
As bartx adviced me, I soldered vSense directly underneath the socket.
The change was clearly noticable V-drop was significantly smaller!
It looks good on software readout, but on DMM it looked even better.
You could say, that the voltage was really stable. Satisfying improvement
Soon I will make some tests on QX6700 (as for now I'm not so brave yet to put there QX9770 :P).
Also more capacitors will be added in the future.
Old 01-29-2014, 09:34 PM
Those sense wires need to be twisted or coax for best performance. You don't want all noise to be picked up by your sense signal, do u?
Old 01-30-2014, 04:20 AM
ivanov's Avatar
That is good to know, thank you master
Will it be sufficient if I twist the existing cables myself?
I have also came up with an idea of making AGP current booster. I will try to solder it today.
Old 01-30-2014, 09:05 AM
ivanov's Avatar
I twisted the cables. Will it do?
I also made the current booster, that I mentioned.
