Old 12-19-2013, 01:10 AM
Lvcoyote Lvcoyote is offline
Originally Posted by FTW12345 View Post
Hi strongisland1,
is it BSOD after system reset? i ever saw that on reference ti by myside.
based on that experience i modified a bios for you.
http://www21.zippyshare.com/v/88888925/file.html
I just installed this BIOS and see that it only has a 115% power target limit? Is that correct? If so can it be raised a bit?
Thanks FTW
Old 12-19-2013, 01:28 AM
Thanks FTW
it says 115% but it's not the same 115% as the stock bios. It is much higher. I only started to hit over 100% at 1.5v.
Old 12-19-2013, 01:30 AM
Ok, testing now. It does work well with the voltage tuner
We'll see how far I can take it! Any idea what the actual power target limit really is then?
Old 12-19-2013, 02:37 AM
FTW12345 FTW12345 is offline
Hi Folks,
It's up to 690W.
Old 12-19-2013, 07:52 AM
nacho_arroyo nacho_arroyo is offline
Thanks FTW12345 for the bios !
Old 12-23-2013, 06:06 AM
bsch3r bsch3r is offline
I flashed provided bios and used the software tool but I am not able to change voltage, neither in Precision nor AB. Am I missing something or do I have to get an EVBot to be able to overvolt the card?
Old 12-23-2013, 09:36 AM
You have to use EVBot or the voltage software in the original post.
AB and Precision will not work at this time.
Old 12-23-2013, 01:26 PM
Well, I did use provided bios (FTW_2002) and provided Classy Tool. In the tool I first disable "auto" and then set a voltage, e.g. 1.2 volts and ... nothing happens. AIDA64 shows the same voltage than before. Am I doing something wrong here?
Old 12-23-2013, 02:34 PM
O.k., now I understand. Tool is working, I put it on 1.3 Volt, however neither aida64 nor precision are showing the voltage change, but I should be running with 1.3 Volt now, because I can overclock the core stable up to 1384 MHz under water (EK)now. Sorry for my noob questions, but it is indeed my first EVGA board (Classy 780 ti). By the way my ASIC is 68,3% only, I am a little bit dissapointed about that, however card seems to overclock well
Old 12-23-2013, 02:57 PM
Don't trust the software to tell you what voltage is set, I don't think they read correctly past 1.21V You'll need a multimeter and one of the Probe it connectors.
Probe it: http://www.evga.com/Products/Product...W002-00-000010
