Go Back   kingpincooling.com > The Lounge > Members Rides
Members Rides Brag about your actual ride or your daily pc rig.
Old 02-22-2011, 07:25 PM
M.Beier's Avatar
M.Beier M.Beier is offline
Location: Copenhagen, Denmark - Yea, origin of LEGO, Mærsk & Muhammed Drawings
Send a message via MSN to M.Beier Send a message via Yahoo to M.Beier Send a message via Skype™ to M.Beier
Thanks for all the kind words!
http://www.aquatuning.de/product_inf...odule-red.html
I honestly cannot find any specification on exact amount of heat it transfers, but I would assume less then a 120mm rad, maybe half, so I would expect maybe 40C water, but even so, it will be ok.... However....
Leads me to a question, would -20C chilled water on hotside make the coldside very cold then?
I will test this rig shortly after CeBIT, hopefully with the GTX580 SuperOverclocked
The bloke that eliminated the term "pretesting" when it is a matter of real benching.
Old 02-23-2011, 07:15 AM
Calathea Calathea is offline
No TEC's are not the best piece of technology.. They will be less efficient with hot side sub zero. I think I would skip TEC if I had a chiller, gains would not be worth the power draw. But of course it wouldn't hurt to test
Old 02-23-2011, 12:09 PM
Bobnova Bobnova is offline
The colder you can keep the hot side, the colder the cold side will be.
If you have -20*c water on the hot side, I'd expect the cold side somewhere from -40 to -60 depending on the heat load going into it.
The colder things get the less heat the TEC can transfer.
Something to keep in mind: The TEC just moves heat, which means your water cooling (or whatever) on the hot side has to get rid of all the heat moved, plus all the heat created by the TEC. It can get pretty gnarly if you're trying to cool a cpu or gpu.
It should work decently on ram, really.
Old 02-23-2011, 03:55 PM
That will never occur in reallife Otherwise we could have a lot of people having -60°C on single-stage phase :-D
Old 02-23-2011, 07:08 PM
I love my mora for inital testing...
Old 02-23-2011, 08:07 PM
No? They're supposed to be 65-70*c between sides in ideal conditions (no heat load), but with only ram heat (15w? 25w?) and a 100w+ tec it seems like it ought to be dropping at least 20*c.
I do know they pretty much crap out entirely around 70 below.
Mine gets waaay down there with a small heat load cooled with 10*c water.
Getting a thermocouple thermometer later this week so I can find out exactly how cold.
Old 02-24-2011, 01:58 PM
EeKy NoX's Avatar
EeKy NoX EeKy NoX is offline
Send a message via MSN to EeKy NoX
Nice! Great pictures buddy !! 4 GPU under water is quite insane.
Hope I will go back on mine soon...
Oh it's official now, you gat your thread in here ^^
I'll be extreme when I'll be grown up !! ...near 60years old
Old 02-25-2011, 04:51 PM
M.Beier's Avatar
Come on msn soon man =)
I think I will start to write a bit more!
Old 02-09-2014, 01:15 AM
kyledavid kyledavid is offline
Send a message via AIM to kyledavid Send a message via Skype™ to kyledavid
Are you going to skip TEC ? It has great look and I love it.
atlantarhinoplastycritic
