Old 02-06-2013, 10:50 PM
cjflis cjflis is offline
Unfortunately I rent, thank-you for the link though that is like the greatest thing ever.
Old 09-01-2014, 02:14 AM
mushy409's Avatar
mushy409 mushy409 is offline
Would it be possible to use the innards from a small freezer unit? I'm thinking pulling the exchange, pump and other guts out of a small chest freezer we have and knocking something up. I can buy one second hand for quite cheap (maybe free)
Old 09-03-2014, 04:37 PM
Masterchief79 Masterchief79 is offline
I think it doesn't work - as the compressors used in fridges etc. work with a different pressure. The pressure in a single stage is much higher - if I remember it correctly.
I know people though who bench their stuff with air cooling - in a freezer That works splendidly. Only thing you should consider is that heatpipes dont work at -25C any more
Old 09-03-2014, 07:29 PM
Really small units usually are to weak to cope with 400+W CPU or 500-800W GPU heatloads....
cooling from scrap, diy stuff, engineering madness, subzero
