Old 02-22-2010, 12:55 PM
road-runner's Avatar
road-runner road-runner is offline
I have the Silverstone Zeus 1200W, when using 2-4870x2 in the middle of a 3d bench it would cut off, bam like someone flipped the switch off. I complained tried to get an RMA about a week and half latter they tell me to switch to single rail or I have to balance the load. How do you balance a load when all PCIE plugs are in use on the 2 video cards? There are no other spots to plug them into. I switched the switch to single rail and it worked so far.
There support sucks, about 3 weeks after the original RMA request they sent me a RMA number even though I had talked to support and switched the switch. I wont buy another silverstone...
Old 02-22-2010, 02:24 PM
Just connect green and and one of black wires together from slave PSU and primary, and rig will power both PSU's same time.
But I would NOT recommend you running two PSU's. If ground connection will break/loose, you will burn you system for sure.
Old 02-22-2010, 02:53 PM
knopflerbruce's Avatar
knopflerbruce knopflerbruce is offline
WHat about 24-pin Y-split or something, won't that solve alot of problems?
bobo, the 5870 lightning you shot, did you save the stock cooler ?
Old 02-22-2010, 05:31 PM
Raja@ASUS Raja@ASUS is offline
I think the Antec 1200 model is the one to get from what I've seen. I have the PCP 1200w and it is a good PSU adn has consistently been one of the top 3 on the market at any given time over the years. However, I think that Antec might have a very slight advantage if you're looking for the absolute best. JG only really faulted the Antec over it's 'need' for the remote caps on the Antec - it's a moot point IMO cos the PSU was designed around that filtering being present. The ripple figures on the Antec unit are excellent all round.
Old 02-22-2010, 06:39 PM
Philly_boy's Avatar
Philly_boy Philly_boy is offline
Send a message via AIM to Philly_boy Send a message via MSN to Philly_boy Send a message via Yahoo to Philly_boy Send a message via Skype™ to Philly_boy
Yeah....I guess in the end Raja is right....dollar for dollar pound for pound the Antec is a very nice unit.....perhaps get two of them?
The Broad Street Bully
| Gigabyte Z87X-OC | 4770K | GTX 780Ti Classified | Corsair Dom Platinums |
| Samsung 840 Pro SSD | | AX 1200i + PC P&C Turbo 1200 SR |
you guys are the best But im vinboe's bytch
Old 02-23-2010, 01:08 AM
chispy's Avatar
chispy chispy is offline
Send a message via Yahoo to chispy
I have a Silverstone OP 1000 and a PC Power & Cooling 1200w , the silverstone craps out during heavy loads on the GPUs if crossfire or SLI High end GPUs, the PCP&C Rock stable. I would say the winner between the Silverstone and PCP&C is the PCP&C hands down.
Old 02-24-2010, 12:01 AM
Hondacity's Avatar
Hondacity Hondacity is offline
Worries Too Much About User Title
There is no multiple PSU's on computer market. (One VERY few are multiple).
Don't listen marketing BS. All these PSU's are SINGLE rail.
I'd go with PC&P, coz they aren't modular and I like them. But actually you can choose any, they are both nice. Silverstone is OEM Etasis, if I remember correctly.
the ss1500 oem is enhance just like the antec 1200
Old 02-24-2010, 12:47 AM
Doesnt do much good when the cut off under load though...
Old 02-26-2010, 04:19 PM
Hondacity's Avatar
what load did you have to cause the cut off?
