Old 02-13-2010, 08:24 AM
Extra cap for +12V power on card, caps for GPU, Vddmem Vddqmem, two extra 6-pin pci-e conns per card, 3+ VR's each card (Vgpu,Vgpu-ovp, Vmem i guess) and all covered with vaseline
Old 02-13-2010, 09:03 AM
Kriztoffer Kriztoffer is offline
Anyone have a overveiw picture of all the compoents named and pointed out on the 5870 pcb?
What would the benefits/gains from doing the mod andre did vs mine?
Old 02-13-2010, 10:20 AM
gains can be none to some. It's very depends.
Old 02-14-2010, 06:42 PM
I think the biggest gain is going to come from the caps... Depending on how many you add and the rating... Thats what I have found on air... too bad I have had too many soldering issues. which turned out to be the iron.... Found a cheapo.. and now I can mod correctly.. sheesh.... ANyway.. put that card under LN2 already will ya...
I have to wait til next weekend for mine...
Old 02-15-2010, 02:47 PM
I've been thinking the same. but if a mod could help my card climb sightly higher, I would do the mod straight ahead.
Thanks for all the help you guys have supported me with!
- Kriz
Old 02-15-2010, 03:46 PM
Just wondering that these caps are placed the right way, I've used my multimeter for reading the spots. But I want to be 100% sure.
don't worry about the legs. I will cover them with my Glue gun. should have gotten some smaller caps, but this will work.
Old 02-15-2010, 04:03 PM
What caps you used. I don't have any 5870 here, so can't check polarity.
Use multimeter in resistance measurement mode. Put black (common) probe on VGA bracket (metal thingy). And put red (ohm measurement) probe from DMM to cap side. One side with have zero resistance - is GND. Another side will have some not big resistance. 0.5 to 10 ohm for GPU's (0.5-2 ohm for monsta gpu's like rv800's) and 10-100ohm for memories. Be aware, that 0.5 is not zero. If you use cheapo DMM and which dont have relative delta mode, short probes before any tests and write down lowest resistance value with shorten probes. This will be your "zero", coz probes, contacts in DMM have their parasitic resistance.
And then put _shortest legs as possible_ of caps to sides of SMT caps, having in mind that negative marked on electrolyte is to zero resistance side (GND) and positive to V+.
Avoid long legs!
Old 02-15-2010, 04:17 PM
when I set my DMM to 2kohm and measure:
- right side gives 001
- left side 012
200ohm
- right side 00.5
- left side 11.9
I shortned the sticks each time.
Old 02-15-2010, 04:23 PM
What caps are these? They "look wrong" like cheapo crap.
Old 02-15-2010, 04:25 PM
lol, cheapo crap
470UF 6.3v
CD11T
- 40 +105c
marked with a J.D logo
