  #41
Old 02-19-2014, 05:49 PM
how did you insulate your card. did you cover the memory at all.
Old 02-19-2014, 08:57 PM
yeah, covered it with a thin layer of eraser
the memory on mine is not good though, can't do more than 1800 even with the loose timings bios
Old 02-20-2014, 12:23 AM
the memory on mine is garbage though, can't do more than 1800 even with the loose timings bios
I really feel like the eraser is not a good enough insulator for the memory. I covered mine in dielectric grease and it helped a lot.
Old 02-20-2014, 12:28 AM
this is what mine looked like after I pulled the pot off.
Old 02-28-2014, 02:50 PM
Is there an XOC bios available that has the loose memory timings?
Old 03-07-2014, 05:44 AM
Dancop Dancop is offline
Sure
Old 03-12-2014, 10:58 AM
VSG VSG is offline
Good to know I am not the only one with this.
Old 03-13-2014, 06:29 AM
Vlada011's Avatar
Vlada011 Vlada011 is offline
Really, that's bad.
Memory on mine can +400 with default LN2 BIOS on stock voltage and I didn't saw signs of close artifacts... But for GPU I'm not sure yet. I must change PSU...
It would be really bad if card can't at least 1300MHz...
With 1900MHz memory I would be completely satisfied but looks like my memory can 80-100MHz more... Only is bad because as I notice good memory and good chip are extremely rear on one card.
I really no reason to use BIOS with different latency for Air.
That mean Samsung is not inferior to Hynix even with tight timings, depend of sample... Because I saw more people can OC and +500 with tight latency for LN2,
maybe and my can, only luck and nothing else. On GTX780 Classified with Elpida I had max 100-110-120MHz, +225 was Max if I remember good.
Old 03-13-2014, 10:38 PM
bob(nz) bob(nz) is offline
Finally won the evga online store lottery and my two babies have arrived - Oh Yeah!!!
Preparation this weekend, and ready for benching in a week on the cold stuff, cant wait
Old 03-25-2014, 09:39 AM
Had some fun...
