  #31
Old 02-11-2010, 03:33 PM
Evocarlos's Avatar
Evocarlos Evocarlos is offline
hey guys
do this look right for 5870?
5x 820-2.5v core
2x 561-6.3v mem bit
2x 820-2.5v for the 2nd voltra controler (i dont know what its for) lol
Old 02-11-2010, 03:50 PM
BustaH BustaH is offline
very nice clean work carl....does the card still work?
Old 02-11-2010, 03:52 PM
Evocarlos's Avatar
thanks b
lol im not sure yet its untested im trying for the 1100 core on air its like -5c in the batcave atm so ideal opatuity to try for more on air
Old 02-11-2010, 04:03 PM
Dualist's Avatar
Dualist Dualist is offline
Very good question Martin. But Carl, I ain't gonna be able to RMA that for ya mate if it's fecked
נְפִילִים
Old 05-20-2010, 07:05 AM
wesjuhdabomb wesjuhdabomb is offline
Had 2 HD3850 256mb while one was dead.. So time for the other to do this mod pics:
2 cards:
12v input stability:
Vcore stability:
Final pic with vmods:
Testing results:
vcore @1,354v (stock) & 837mhz gpu:
idle: 1.354
load: 1.350
vcore @1,454v & 900mhz gpu:
idle: 1.454
load: 1.449
vmem @2.14v (stock) & 1000mhz mem:
idle: 2.14v
load: 2.14v
12v on card@ 900mhz gpu, 1000mhz mem:
idle: 12.06
load: 11.96
12v psu:
idle : 12.11
load: 12.04
Old 05-23-2010, 02:07 PM
Mack4033 Mack4033 is offline
Any volts mods for the 295 Coop
Thanks,
Mack4033
Old 05-24-2010, 07:11 PM
G H Z's Avatar
G H Z G H Z is offline
sb cant touch this
First find which power source the slot gives by doing continuity check with the pin on the pcie
Question: a continuity check between this location and your 6+2-Pin connectors to verify it's on the same rail?
Old 07-12-2010, 01:08 PM
Evocarlos's Avatar
i think sham means probe the pci-x pin to the inducters to find which ones are powered from the mobo and then from the pci-x 6pin plugs to inducters to find which ones are fed from the 6pin's
this pin is connected --
-- to these inducters
i really came one to say ive redone my cap mod on a diffrent 5870
the score is poo poo but i was relly trying for the gpu clock
Old 09-13-2010, 01:03 AM
reggiesanchez reggiesanchez is offline
Ok so you can solder one or two molex connectors to the card at the appropriate leg of inductor, with the yellow +12v wire there of course:.
Great guide thank you for sharing. I read this a few months back an there is still one thing I am confused about. Are you saying it is safe to add power straight to the choke like that. If so would this be worthwhile on a single rail psu? Or did I misunderstand and you are just using for a measuring point.
Old 09-13-2010, 01:45 AM
reggiesanchez
Input +12V inductors just used as bypass filters/current capacitors feeding mosfets. They are connected to +12V input power plane anyway onboard, by adding direct connector/wires to it you just lower resistance for high-current path. Do not confuse that input conductors with high-power output inductors, or you will burn your card!
These mods not related to single or multi rail psus Actually 99.9% of all PC PSUs are single rail, but most have extra current shutoff divided lines .
