Old 12-05-2009, 02:41 PM
hi barrie, its fine, but usually those high capacitance has kinda high esr as well, so not 'ideal' but prolly of some benefit still, as for 280gtx, i think the switching frequency for gpu is pretty high? 800+khz volterra solution? won't even have enough time to charge up to 2200+
Old 12-05-2009, 04:37 PM
bazx's Avatar
bazx bazx is offline
thanks peter
yes its got the volterra solution
this make sense,i will get some 500s
baz
Old 12-06-2009, 01:04 PM
TONY GAL's Avatar
TONY GAL TONY GAL is offline
nice information shammy !
thanks a lot and congrats!
Old 12-06-2009, 02:59 PM
Dualist's Avatar
Dualist Dualist is offline
Great info Peter, will have a go once I get some scores logged first incase I kill anything
Old 01-15-2010, 04:33 PM
Old 01-28-2010, 10:37 PM
kayl's Avatar
kayl kayl is offline
Heres what my hd 5870 turned out like. without the caps the vcore was all over the place, 1.5,1.4,1.3,1.4,1,4 falling and rising all the time thanxs shammy
i also marked for others the + and - points. ppl should still check before soldering, check twice solder once
Old 01-28-2010, 10:52 PM
My 7800GTX prepped.
Short guide
Result
Old 01-30-2010, 06:21 AM
nigel's Avatar
nigel nigel is offline
Send a message via MSN to nigel
If I understand correct,
you are adding in new cap's for stabillity?
And using adjustible resistors to adjust the voltage?
Old 02-01-2010, 03:15 AM
Yep, as usual more capacity decrease voltage ripple and noise if properly chosen and solder works done. Adjustable resistors used to tune feedback voltages for DC-DC convertors, which allow us to regulate Vout.
Old 02-07-2010, 01:49 PM
nigel's Avatar
and how do you find out where to solder the new adjustable resistors? The caps don't seem to hard to figure out but the adjustable resistors seem strange
Could be my lack of knowlidge with electronics
http://nigelpoint.blogspot.com/
The duck is here together with the Frozen Duck
