  #331
Old 02-24-2013, 10:35 AM
subzero subzero is offline
3.3 volt rail
used 3.3 volts from psu
now i have to connect ev bot and see if i can change the voltage
with some 10 ohms resistors the zombie works but
the vrms become very hot.
Old 03-02-2013, 03:40 PM
please if someone can help me with chil asp1000c-12 pinout i
found en pin and 3.3 power and i have 0.85 volts outpout on chokes
all i neet is fb pin and ocp ovp if exists
Old 03-02-2013, 04:02 PM
OCP mod :
Old 03-02-2013, 04:31 PM
Halo_003 Halo_003 is offline
Send a message via Skype™ to Halo_003
Welcome back Chiller. Please check your PMs/email/paypal. I appreciate you not PMing back nor sending your part of our trade which ended up costing me my first 285 Classified.
I've sent you NUMEROUS things regarding our trade because you never answered after you got my 285 in hand.
i7 3820 @ 5.25GHz --- X79 Classified --- 4x2GB Dominator GT 2000C8 --- GTX 580 Classified Ultra/GTX 285 Classified/GTX 480/2x GTX 295 --- SPH 1050W+1300W --- RAID 0 Vertex 2 90GB
Old 03-02-2013, 04:38 PM
whent for 6 months to afganistan, and before i sended pack to you
Old 03-02-2013, 04:42 PM
Please drop me a PM then, I never got anything from you.
Old 12-30-2013, 02:44 AM
bartx bartx is offline
Hello again
I connected 8800GTX VRM to 7900GS yesterday. Card works fine, but still have the same problem as it was on stock VRM. GPU voltage over 1.65V results in black screen in 3D. I have no idea what is wrong, there is no OCP or OVP. Anyone have an idea what's wrong? I'll post pictures later today.
Thanks
Old 12-30-2013, 08:26 AM
GPU don't like voltage?
Or maybe too much voltage drop on GPU actually, measure actual voltage on back of GPU cap.
Old 01-02-2014, 08:13 AM
Desoldered ISL6568 voltage controller and it works fine now - tested up to 1.75v. It's really interesting, it looks like there is an output pin from this controller, which can disable GPU, when 1.65v is exceeded.
Old 06-17-2014, 10:36 AM
siouxx siouxx is offline
Default zombie from gtx 580 (uP1981A)
Hi I'm trying to make a zombie from a gtx 580 (the gpu is burned, was reflowed, reballed, re-everything... but the power supply is still working). The big problem I have is that I can't find the pinout of vrm, uP1981A. If anyone has the full datasheet and could send me, I would greatly appreciate.
mad engineers, overclocking solder guys, zombie
