Old 07-18-2015, 04:06 AM
First test under LN2 : 1800MHz @1.45v -110C and 2100MHz for memory stock
Now test my 5960X (4.5GHz cinebench 1.18v)
Old 07-19-2015, 09:20 AM
Dancop Dancop is offline
https://m.facebook.com/story.php?sto...ef=fbwaexpcopy
Here we go!
Old 07-19-2015, 01:58 PM
Originally Posted by Dancop View Post
Good job and thanks for informations
Old 08-02-2015, 11:21 PM
elmor elmor is offline
If you use Windows XP, please make sure you're running latest GPU-Z 0.8.5. Otherwise there's a throttling issue with these cards. Clocks would be stuck at 405Mhz core and PCI-E Gen 1.1 while GPU-Z was open. Closing it would bring things back to where they should be.
Only applies to GPU-Z older than 0.8.5 on Windows XP, was tested with 344.11 and 353.30 drivers.
Old 03-29-2016, 04:16 AM
mahaudi mahaudi is offline
Goes the hardmod with 980ti Strix rev.2 ?
My 980ti Strix have Samsung Chips and no 4 Pin Molex on PCB.
Old 06-22-2016, 12:51 AM
fat4l fat4l is offline
Hi. Anyone else has tried this mod ? I own 2 locked strix with .81 bios.
Ver 2.00.
Can anyone explain more about this hard mod ? I'm new into this but I would like to try it out!
One more question. Can someone upload a tool/program/utility that allow to change voltage on a locked strix ?
(Would this work ? its for 980 strix not TI)
http://forum.kingpincooling.com/show...65&postcount=1
Thanks
