  #161
Old 09-08-2010, 11:49 PM
Viss's Avatar
Viss Viss is offline
Send a message via MSN to Viss
CBB mod is for booting colder, chips wil stil have their CB. Even with my chip that doenst have a CB i have to boot at -140 or so, colder = no go.
Bart
Old 09-09-2010, 02:19 AM
Raja@ASUS Raja@ASUS is offline
Originally Posted by ZenEffect View Post
where can i snag a beta of this new bios w/ clock skew?
You won't need clock skew as most of these boards have dual clocks generators. As far as i know the skew setting on these boards will offset both clockgens by the same value, which defeats the purpose of skewing one domain against the other.
Old 09-11-2010, 12:23 PM
ZenEffect ZenEffect is offline
i suppose but it also is supposed to contain better turbo mode control... one thing that i never touched on because the lack of being able to manipulate the multi's resulted in lower frequency than with them off.
either way... i still want the bios.
Old 10-02-2010, 03:34 PM
Mack4033 Mack4033 is offline
This was my old bios set up now I have the A70 Bios and changes were made I need some in put in the following...
CPU Skew Control 0ps
Clock Gen switch Mode
CPU PWM Frequency: 1189KHz
VTT PWM Frequency: 634KHz
DDR PWM Frequency: 634KHz
CPU Signal 1: Less
CPU Signal 3: -31
CPU Signal 4: -31
CPU PCIE 1/2: Auto
DDR Signal 1/2/3: Auto
DMI Signal: -31
PCH Signal -31
Case; Corsair Obsidian 800 D
Current as of 10/02/10
EVGA P55FTW MOTHERBOARD BIOS TEMPLATE
Bios Version: 08.00.16
Build Date: 10/02/10
Corsair Power Supply 1000 HX 1000 Watt
Video Card 2 GTX 480's in SLI
Water Cooling System Information
FANS: 3 Black ULTRA KAZE 120mm fans moving 133.60 CFM OF AIR
Pump;Swiftech MCP655 12 VDC Pump
Lines 1/2 Custom Made
Radiator; Swiftech "Stackable" series radiators 1 MCR320-QP stack mounted inside the top my Corsair Obsidian 800 D with 3 Black ULTRA KAZE 120mm fans moving 133.60 CFM OF AIR out the top of the computer case.
Fan Controller; Aero Cool
Reservoir; RAD-Reservoir Clear Acrylic Design
Coolant; Distilled Water
UV Reactive Dye; Feser UV Green Dye
CPU Cooling Block; Swiftech CPU Block 775 that is one reason why I got the P55 FTW
*More custom cooling; I made a custom fan shroud to pull more air out of the back of the case
As of 3/8/10
2 SSD Vertex 60GB in Raid 0
New i-7 870
Prod Code: BX8060517870
MM# 903875
FPO/Batch# L926B294T
Ram Perfect Storm 2133 I have oced to 2300 but not stable, it will run from 2266-2299 8-8-8 24 but 7-7-7-24 as of 2/15/10
Dummy O.C : [Disabled]
Target CPU Frequency : 4.800
Target Memory Frequency : 2022
CPU Multiplier Setting : (22)
CPU Frequency Setting : [209]
PCIE Frequency Setting : [106]
QPI Frequency Selection : [4.2700 GT/s]
MCH Strap : [1867]
Extreme Cooling : []
EVGA VDroop Control : [Without Vdroop]
Bootup CPU Vcore : [1.45V]
Eventual CPU Vcore : [1.58.8V]
DIMM Voltage : [1.66V]
Bootup CPU VTT : [1.45V]
Eventual CPU VTT : [1.475V]
Current PCH Voltage : 1.20V
PCH : [1.225V]
CPU PLL : [1.95v]
DIMM 1/2 DQ Vref : [+0 mv]
DIMM 3/4 DQ Vref : [+0 mv]
DIMM 1/2 CA Vref : [+0 mv]
DIMM 3/4 CA Vref : [+0 mv]
CPU PWM Frequency : [1867 Khz]
VTT PWM Frequency : [634 Khz]
DDR PWM Frequency : [634 Khz]
CPU Signal 1 : [Auto]
CPU Signal 3 : [Auto]
CPU Signal 4 : [Auto]
CPU PCIE 1 : [Auto]
CPU PCIE 2 : [Auto]
DDR Signal 1 : [Auto]
DDR Signal 2 : [Auto]
DDR Signal 3 : [Auto]
DMI Signal : [Auto]
PCH Signal : [Auto]
*Memory Configure*
DRAM SPD : [Standard]
DRAM Frequency : [1333 Mhz (2:10)]
Target Memory Frequency : 2022 mhz
DRAM tCL : [7]
DRAM tRCD :[7]
DRAM tRP : [7]
DRAM tRAS : [24]
DRAM tRFC : [Auto]
DRAM tRRD : [Auto]
DRAM tFAW : [Auto]
DRAM tRTP : [Auto]
DRAM tWR : [Auto]
DRAM tWTR : [Auto]
Command Rate : [2)]
Back to Back CAS Delay : [Auto]
CHA Round Trip Latency : [Auto]
CHB Round Trip Latency : [Auto]
Memory Low Gap : [] Auto
Memory Remap Feature : [Enabled]
PCI MMIO Allocation : 4GB To 1024MB
Memory Hole : [Disabled]
DRAM Margin Ranks : [Disabled]
*CPU Configuration*
Hardware Prefetcher : [Enabled]
Adjacent Cache Line Prefetch : [Enabled]
MPS and ACPI MADT ordering : [Modern Ordering]
Max CPUID Value Limit : [Disabled]
Intel (R) Virtualization Tech : [Enabled]
Execute-Disable Bit Capability : [Enabled]
Intel (R) HT Technology : [Enabled]
Active Processor Cores : [All]
A20M : [Disabled]
C1E Support : [Disable]
Intel (R) SpeedStep (tm) tech : [Disable]
Intel (R) C-STATE tech : [Disabled]
Thanks,
Mack4033
<message edited by mack4033 on 0 mins. ago>
Old 12-30-2010, 04:38 PM
posershadow posershadow is offline
Originally Posted by Beaux View Post
I had issues with my first go at the p55 200.. Did the cbb mod and it does run up to -180c but I get a d3 boot error no matter what at anything above -140c so it may have been the chip or the mod was acting weird... I'll have to confirm later with a different chip.. But yeah, it seems that everytime I changed a setting in the bios it had to turn off.. Kind of a bummer..
Weird, I'm getting the same thing as you now. Stalls at d3 continuously.
Old 01-13-2011, 11:03 PM
XtremeCuztoms's Avatar
XtremeCuztoms XtremeCuztoms is offline
Send a message via MSN to XtremeCuztoms Send a message via Skype™ to XtremeCuztoms
thread bump....
great info here. got my 1st Evga board.. e659
replaced a p55a-ud6
only running chilled air cooling right now but will run some dice soon on this i5 750
thanks for the great info
Old 10-23-2015, 09:18 AM
Any chance at getting some of the photos in the OP restored? I just got an E659 yesterday and it has a LOT of BIOS settings.
EDIT: Link to A58 BIOS in the OP is dead as well. Anyone have it?
Old 10-28-2015, 12:07 PM
Searched around a lot trying to find the old images and no luck. Sent Shammy a message on FB but I'd honestly be surprised if he still has them.
