Old 01-19-2015, 08:22 AM
Very nice Dumo.
I have a bit of an odd problem.
With the original LN2 bios, XOC software works fine, normal operation, normal limits.
I flashed to the fixed memory bios and lost vgpu control with GPUTweak, and vmem max available is now 1.65V
Any ideas?
If anyone has the original LN2 bios, please email/PM it to me.
Old 01-27-2015, 12:56 AM
coolice coolice is offline
Originally Posted by Gunslinger View Post
Very nice Dumo.
Any ideas?
Hey Mike,
Could you try this GPUTweak?
https://www.mediafire.com/?6qzi3xzfb1bhb6k
Old 01-27-2015, 08:02 AM
I'll give it go this week, thank you!
Old 02-02-2015, 06:00 PM
The new GPUTweak is working with the original bios. I will retry the fixed memory bios when I get a chance. Thanks TL !
Old 02-03-2015, 08:17 PM
Fixed memory is working also! Thanks Master TL
Old 02-04-2015, 09:05 PM
glad it fix the issue, didnt expect it happens to recent manufactured card
older version GPUTweak was fine all the while when we testing the cards
Old 02-11-2015, 01:21 AM
Claviger Claviger is offline
I ordered my Matrix today wewt. Using the OC Panel that comes with the Rampage 4 BE, I will have full control of core/memory/pll voltage once the LN2 pads are closed right?
Old 02-11-2015, 05:13 AM
nacho_arroyo nacho_arroyo is offline
Correct Claviger, also can use GPUtweak.
Old 02-19-2015, 08:05 AM
Dum3 Dum3 is offline
If someone can upload stock ln2 bios somewhere would be great
Old 02-19-2015, 11:48 AM
https://www.dropbox.com/s/hs0iy0qcbf...Stock.rom?dl=0
here u go
