Old 10-09-2014, 05:21 PM
wizerty's Avatar
wizerty wizerty is offline
Originally Posted by hiwa View Post
My gt2 is low because high memory, will bench 2100 next time then should be OK.
Or its win 8.1 magic?
I don't know... it was only for an OCing show. OS wasn't optimize, no tweak...
I made Voltmod 10min before going to train station, 1st boot with vmod on live.
I will bench it again properly after MOA.
Old 10-10-2014, 07:36 AM
slapmehard slapmehard is offline
My card runs the ram at 8400 np but it does not like the modded bios one bit and the soft mod app crashes my system.
Just going to try to shunt resisters and use the hotwire points.
Just crossing my fingers its the same how its always been
I got no love
modded power sense I did bridge the pad and removed the resister using a vr I get no movement in voltage at all
I get spaztic sometimes though so will try to go over it again.
Old 10-12-2014, 09:11 AM
Dum3 Dum3 is offline
So soldering hotwire points to oc panel==? no love?
Old 10-12-2014, 12:06 PM
I will double check the solder on the pads it might not have made good contact. Plus I always get a little giddy when I get new cards
Had it -50c was ok could have used some voltage thou the temps did not even swing with only 1.22v
nah no go at all I checked like ten times again.
the oc panel I did not try at all I forgot about that tbh
Old 10-13-2014, 12:45 AM
coolice coolice is offline
Originally Posted by wizerty View Post
Did you try your mem on air @stock volt ? volt / cold help ?
Mine can do 8100 on the edge under air-cooling ( stock volt, stock cooler, stock bios).
I made Voltmod for mem and pll, and I tested it under cold yesterday @8100 for 1.7v -> Stable
It was during an overclocking show... so I wasn't able to test other bios. I will try higher mem later.
My PLL coldbugboot @-60, need TL pll mod
single phase default 1.1v or 1.15v
2-phases default 1.5v
Old 10-13-2014, 08:06 AM
wizerty's Avatar
Perfect, only powercard are missing now
I got no love
IF you use hotwire, take care, "mem" and "gpu" read point are reverse ( mem is gpu and gpu is mem). I don't know if OVC and OVM are reverse too or if they are in the good position.
Old 10-13-2014, 04:08 PM
Anybody have the stock bios?
I flashed to the shammy bioss and the card is total crap now... was so much better on default..
Old 10-13-2014, 04:36 PM
Ok so I need to use the upper one then for the vr and gpuv.....and you know I did not read ram volts as I turned the vr . I used the hole next to the read gpu but I stopped at what should have been 1.40v and no volt increase.
so I will get right on that now and will just read memory volts as I turn
this one @ tpu
http://www.techpowerup.com/vgabios/1...96-140910.html
Old 10-14-2014, 10:13 PM
elmor elmor is offline
People who have issues with the unlocked bios, can you double check that your turbo frequency is actually the same? Monitor it with GPU-Z while running a GT for ~15 seconds. You might be hitting the maximum power target with default bios and have throttling.
Old 10-15-2014, 03:22 PM
mortisboy's Avatar
mortisboy mortisboy is offline
I also have the same problem, i haven't tested yet on ln2 but on air stock bios does +200 on core stable fsx, boost is 1528 monitored with gpuz
but with unloked bios i can't even run +140, i will also check boost freq as elmor said with unlocked bios!
