Old 09-09-2014, 08:40 AM
2666 8-12-12-15 DDR4 CL8 fun
Updated Cinebench with Tighter timing and higher cache frequency
Old 09-09-2014, 09:31 PM
l0ud_sil3nc3's Avatar
l0ud_sil3nc3 l0ud_sil3nc3 is offline
think its more a 32bit issue,
Win7 64
7m 19.861
Winxp SP3 64
7m 11.844
Winxp SP3 32
7m 39.375
dont have win7 32bit to verify this hypothesis though
With 5820K, I get 9:41:xx at 4Ghz and W7 x64 all stock I get what I got above.
Installing W7 x32 bit now Shammy
Old 09-10-2014, 04:51 AM
Hazzan's Avatar
Hazzan Hazzan is offline
Send a message via MSN to Hazzan
5.8Ghz with 4600 Uncore and memory tight 3100 easy...
AOCC 2007 - AOCC 2008 - GOOC 2008 - MOA 2009 - MOA 2010
Old 09-10-2014, 05:10 AM
way to go hazzan
LS for PI XP SP2 64bit is the fastest.
waiting for ur 7 32bit results ...
Old 09-10-2014, 08:34 PM
Originally Posted by hiwa View Post
way to go hazzan
Same thing hiwa with Windows 7 x32 bit (9:05:xxx with 5960x)
Maybe need to install chipset + mei?
Old 09-12-2014, 06:50 AM
I guess I am black balled by Asus, have fun guys wish I could have joined the fun with you guys
Old 09-12-2014, 11:04 AM
Naw Splarf, I'd never black ball you, maybe others but not you
Just thought u are so into the 4970ks
Tried a real retail (not USA ES) for the first time, week 22 I thought it was gonna be bad, but ended up being really good in cache Freq and very decent in core frequency:
http://i.imgur.com/PAEdImQ.jpg
SR20Q
3422B720
BIOS 0702:
https://www.mediafire.com/?8fzmhncimnt7m79
Updates Device compatibility
Improves DRAM Compatibility
@ F1 Error (Be it from over-voltage or CPU Fanspeed), added message to remind Raid users of Raid configuration
Adds 3 DRAM Tuning options:
DRAM Swizzling Bit 0 – Disable this item may help the DRAM overclocking
DRAM Swizzling Bit 1 – Disable this item may help Micron DRAM overclocking capability.
DRAM Swizzling Bit 2 – Disable this item may help the DRAM overclocking capability.
Old 09-12-2014, 11:26 AM
Looks like xp 64bit sp2 is the only way here. Time to tweak...
Old 09-12-2014, 10:24 PM
DRAM Ratios > 2400 not working with 125 strap on this ver, will get this fixed soon,
Old 09-13-2014, 01:04 PM
streetmobo streetmobo is offline
hello Shammy
possible to have bios 0010 for RE5 ?
