  #241
Old 04-23-2015, 04:04 AM
FlanK3r's Avatar
FlanK3r FlanK3r is offline
Send a message via ICQ to FlanK3r
Hi Guys, what recommend for LN2 and aircooling benchamrks (mix of Superpi/hyperpi, Cinebench, 3D Marks 11/fire strike)?
Now I have long, long time 0008, its 1001 better? Or any tiup of BIOS? Thanks.
AMD Athlon 3000+, Athlon 3200+, X2 4600+ EE, Athlon 5150 (Kabini), Athlon 860K (Kaveri), AMD Phenom II x2 550 BE,2x PII x4 965 BE, PII 970 BE, PII 975 BE, PII 980 BE, 1090T BE, 1100T BE, AMD A8-3850, A8-3870K, 5600K, 5800K, 6800K, 7850K, FX-8150, FX-8120,FX-4300, FX-6300 FX-8300, FX-8320, FX-8350, FX-8370E, FX-8370, FX-9370, FX-9590. Intel core i7 2600K,core i7-3770K, core i7-4770K, i7 980x, Intel core i7-3930K, i7-5960X
Old 04-23-2015, 06:38 AM
nacho_arroyo nacho_arroyo is offline
I find 1001 too much better than older, i am on this. I dont test the new ones, like 14xx and 13xx.
Good luck!
Old 04-23-2015, 09:14 AM
FlanK3r's Avatar
thx, I flashed 1001 now
Old 01-11-2016, 12:49 PM
Doug2507 Doug2507 is offline
Had a play with this for 1st time at the weekend. Few teething issues though...
Rve 3.1/bios 1800
Every other restart I was hitting debug 94, reset would power off, and every restart cycled 00 about 5 times before boot followed by cpu over volt err before bios/win.
Initial run of 5.3/4.3 -90 deg no issue CB15 (1.65/1.35/2.1, all DE 1.35). Raised core to a moderate 5.7 (v.good chip on ambient, 1.1 x45 cb15), 101 (Vantage) followed by a half hour of cycling 00, needing psu off, 33/53 booting once in a blue moon.
Any suggestions? Away with work for a bit now but inclined to flash 1001 and run another set of ram I know is 100% when back home. (Mems for testing were 2666 fury s running 3k14 1.45, bought used and 1st run with them)
Old 05-03-2016, 08:46 AM
tistou77's Avatar
tistou77 tistou77 is offline
Hello
I do not know if there is (still) people from Asus staff here, but there have a bug in the bios (or know if this is normal) for Rampage V Extreme
With the strap 100, if I put the "Source Clock Tuner" option on 60 (as advised by Asus) M2 slot is in PCIe 2.0
If I leave on Auto, the M2 slot is in PCIe 3.0
Is this a bug or not ?
Thanks for your help
Sorry for my english
MB: Rampage IV Black Edition
CPU: i7 4930K @4.5ghz
RAM: Corsair Platinum 4x4Gb 2666 C10
GPU: ZOTAC GTX770
PSU: Seasonic Platinum 760W
OS: Samsung 850 Pro
DATA: Samsung 830
Old 05-10-2016, 06:36 AM
Is it almost time for RVBE?
