Old 09-04-2014, 09:38 AM
Hyperhorn's Avatar
Hyperhorn Hyperhorn is offline
Send a message via ICQ to Hyperhorn Send a message via MSN to Hyperhorn
Great thread, I recommend downloading the OC guide PDF!
If you want to use CPU-Z for checking frequencies set Sensor=0 and SPD=0 in the CPUZ.ini. Doing so reduces the the starting time to a normal level and you won't miss any frequency readout.
The Initial value finished
PI calculation is done!
Old 09-04-2014, 11:57 AM
Originally Posted by hiwa View Post
Use fat32
same error message using fat32
Old 09-07-2014, 09:03 PM
l0ud_sil3nc3's Avatar
l0ud_sil3nc3 l0ud_sil3nc3 is offline
Having some issue's with XP, all installed well but it is super slow like some sort of device driver issue.
Old 09-07-2014, 09:24 PM
Getting acclimated on air
Old 09-07-2014, 10:22 PM
coolhand411's Avatar
coolhand411 coolhand411 is offline
so many issues with XP lately...anyone have good stripping guide for W7 ?
Old 09-07-2014, 11:43 PM
Dumo Dumo is offline
4X8GB and 4x4GB Hynix tests
1.35V
1.47V
1.65V
Old 09-08-2014, 09:06 AM
tistou77's Avatar
tistou77 tistou77 is offline
Hello
Apparently Shamino made ​​a guide for OC on the RVE, it is possible to have it?
Thanks
Sorry for my english
MB: Rampage IV Black Edition
CPU: i7 4930K @4.5ghz
RAM: Corsair Platinum 4x4Gb 2666 C10
GPU: ZOTAC GTX770
PSU: Seasonic Platinum 760W
OS: Samsung 850 Pro
DATA: Samsung 830
Old 09-08-2014, 11:41 AM
think its more a 32bit issue,
Win7 64
7m 19.861
Winxp SP3 64
7m 11.844
Winxp SP3 32
7m 39.375
dont have win7 32bit to verify this hypothesis though
Old 09-08-2014, 11:42 AM
https://www.asuswebstorage.com/navig...24D86144113FCY
First page.. First post..
Old 09-09-2014, 04:03 AM
Started test the new monster of shambolo
test setup:
16 GB (4x4) G.Skill Ripjaws4 DDR4-3000 MHz CL15-15-15-35-2N 1.35V Single-Sided
ASUS Rampage V Extreme
ALL AIR
3000MHz CL12 1.55Vdimm 1.0V NBV
3100MHz CL12 1.55Vdimm 1.0V NBV
to have high Cache you need cold CPU, here i have CPU under Ln2 -50
3000 CL11
Vdimm: 1.8
Vnb : 1.4
some intressting score
3050 Cl11 +5078MHz Cache Maxxmem
3000 Cl11 Highest Aida read we ever seen ?
3000 Cl11 Cinebench at only 5280Mhz efficiency is great caz the tight ram and high nb
CPU AND MEMORY under LN2
No CB on S-Sided MFR but there is always cold spot point for this kit i used -120
Some more score here CL10 under Ln2 is done
3.0GHz Cl10
3080 CL10 with 13tRCd is just nice too se but more than that 5130 Uncore on RVE QuadChannel with memory is WOW
