  #71
Old 04-17-2015, 04:33 AM
basco basco is offline
i think i got it somewhere saved-lookig for it 8pack
Old 05-06-2015, 06:47 AM
all i got for 780ti-hope this helps 8pack
https://www.dropbox.com/sh/wwewy6jfx...JiAfq1IZa?dl=0
Old 06-03-2015, 10:24 AM
wael87 wael87 is offline
hello,
i got the MATRIX R9 290X , ans i need the original BIOS file . Please can any one help me by sending a link to download it ? i searched on internet but not found any file .
thank you .
Old 06-03-2015, 10:27 AM
by the way i tried the Bios that coolice posted in the original post on the first page (LN2 bios for 1400-1800 memory clock), it work but temp idle is 65 C , even i didnt overclovk the card. (1050/1350)
Old 06-04-2015, 04:02 AM
Hello,
well i think that i killed my ROG MATRIX 290X .
i explain you the problem.
not having found the orgianal BIOS of the card, I decided to flash the BIOS from the ASUS DC2 R9 290x Version ( 1050/1350 ) . Flash went well , but after Flash I tried to increase the GPU frequency to 1200 MHz with 1.3V and when I clicked apply with asus teawk tool, the pc suddenly stops . when I click on the start boutton nothing happens . the PC starts with the card without connecting 8 Pins. I tried to locate the default, and I found that a short sicrcuit occurs when connecting cables 3 12V spotted on the attached picture.
on the PCB I have not seen signs of burns or cuts .
Any one can help me? RMA gonna accepet my card ?
They can say if Bios Was flashed ? knowing that the card will not start if they want to try it ...
i bought it 10 days agos for 300
Old 06-04-2015, 04:10 AM
sorry for my bad english , im french thats why i cant write perfectly.
Old 06-06-2015, 01:13 AM
what about the second bios?
quote from tpu review:
ASUS included a dual-BIOS feature on their card, which lets you pick between a BIOS optimized around a normal operation or liquid nitrogen use. The LN2 BIOS also serves as a backup should something go wrong during a BIOS flash. Unfortunately the BIOS switch only works after connecting the LN2 solder posts near the back of the card, so maybe temporarily bridging it with a screwdriver is a solution for that, if you just want to recover your BIOS.
