Old 04-28-2014, 07:02 AM
Dumo Dumo is offline
Matrix 290X
GPU Tweak Ver. 2.6.2.0 from TL posted up
0.95V @ 1100+ and memory defroster help with blackscreen benching
GPU@1.475V / Mem@1.73V
No cb/cbb
Run out of ln2, heaven next..
Old 04-28-2014, 08:57 AM
Originally Posted by Dumo View Post
Matrix 290X
Can you clarify what this means?
Old 04-28-2014, 11:50 AM
coolice coolice is offline
0.95v and 1.8v are only for 290x, these help to bench with screen at lower temp
Old 05-06-2014, 09:28 AM
8 Pack's Avatar
8 Pack 8 Pack is offline
All flashing Firmware on 780 Ti Matrix make sure you do with LN2 switch enabled or it wont flash. Just a heads up!!!
Old 05-07-2014, 12:09 AM
16 pads by hand next to each other, thanks Adam
Old 05-07-2014, 08:05 AM
looking good Dumo!
Old 05-24-2014, 02:34 AM
Dancop Dancop is offline
Hey guys,
Need some help with 780ti Matrix.
I havent got the panel...is it safe, clocking it with Software? Or better with trim or hotwire?
And if Software...irog update or not?
Old 05-24-2014, 05:29 AM
Hazzan's Avatar
Hazzan Hazzan is offline
Send a message via MSN to Hazzan
Originally Posted by Dancop View Post
Hey guys,
at this time better way with VR for VGPU and Nvidia inspector or AB for raise clock core and memory clock my friend..good luck and waiting your beast number from you
AOCC 2007 - AOCC 2008 - GOOC 2008 - MOA 2009 - MOA 2010
Old 05-24-2014, 11:24 AM
Now I hotwired the card with the R4BE OC Panel...and it shows 0,952 VMEM and 0,6VPLL
I cannot adjust any of these things thorough it...software works perfectly, but not the Hotwire!
Next thing is...how do I flash the IROG?
Old 05-24-2014, 01:40 PM
STOP!!!!!!!!!!!!
Thanks to 8Pack and Benchbros...I solved the problem....MASTERFAIL!!!!!!!!!!!!!!
