Old 04-02-2014, 09:43 AM
Does GPU tweak have both vgpu and vmem control? (for LN2 use)
Old 04-03-2014, 02:11 AM
Originally Posted by 8 Pack View Post
GPU tweak that comes with both cards works fine for me.
With Ti if you boot up in LN2 mode stock volts is 1.2v.
You can use both software and panel to adjust volts no problem.
Thanks 8 Pack.
I make news tests tomorrow
Old 04-13-2014, 10:53 AM
wizerty's Avatar
wizerty wizerty is offline
did we need disable.exe with these card ?
Old 04-22-2014, 02:27 AM
coolice coolice is offline
For Matrix 780Ti
iROG update
- fix 1.6vGPU++ bug
- added LLC disable
LLC disable tool
- required iROG update above
- works for Matrix/DC2 780Ti
- if you SLI with mixture of Matrix and DC2, use this disable utility for disabling OVP/OCP first before you turn off LLC
Use this GPUTweak for software OV
Old 04-22-2014, 06:04 AM
dRweEz dRweEz is offline
thanks for the update coolice
Old 04-23-2014, 04:06 AM
Vivi Vivi is offline
TL,
there is no LLC on the matrix cards by default, what does the disable tool do when we use it?
thanks for the irog update!!
Old 04-23-2014, 08:45 AM
Originally Posted by Vivi View Post
TL,
was told by somebody that they don get constant vGPU when running benchmark
it is optional, if its work fine for you without it
Old 04-23-2014, 08:57 AM
8 Pack's Avatar
8 Pack 8 Pack is offline
Zero LLC allows for over 1.6v load in my case. Otherwise OCP/OVP. Thanks TL.
I get constant voltage under load no matter what LLC.
Old 04-23-2014, 08:58 AM
8 Pack's Avatar
Yes Mike
Old 04-25-2014, 09:28 PM
Single card on LN2 - 3rd Place globally for Catzilla 1440P
1600 boost on the core, memory at 8100 MHz
1.5 Vgpu
1.71 Vmem
200% power limit
74.8% ASIC
-122 C
4960X
Asus GTX 780 Ti Matrix Platinum - K|ngp|n Tek9 Fat
Rampage IV Black Edition
4x4GB Corsair Dominator Platinum
Corsair AX1200i
