Go Back   kingpincooling.com > KINGPINcooling.com Official Support > Product Support
Product Support Insulation and Usage Guides
Old 10-26-2012, 04:03 AM
michael_rw's Avatar
michael_rw michael_rw is offline
Originally Posted by k|ngp|n View Post
Actually it goes flush this one is just a little fresh for pics in guide, I wrap it really tight and eventually after a few mounts it forms to the sides of the container and rods and fits just as tight as slip on piece of insulation. Its really no difference.
very nice bro
Originally Posted by Seebs View Post
For the gray part... I've always used Frost King FV 516... It is sticky on one side so you can just cut two pieces and then stick them to each other to get a thicker piece that won't stick to, or leave any gunk on your pot.
that frost king has foil on the non-adhesive side? or does the foil part peel off? ive seen that before at home depot but was turned off by the foil..
Originally Posted by dRweEz View Post
Check this Velcro from HobbyKing. I have used it before and it has great hold. Perfect for this type of job.
nice recommendation from tha docta'
Old 10-26-2012, 07:58 AM
Great guide Vince, thanks!
The foil peels off (and does so easier with a little heat; a hairdryer will do the trick). Frost King is how I've insulated my boards for a couple of years now and I've never had a moisture problem. Every board gets the same treatment:
  • Pot insulation with plenty of blue shop towels around it.
  • 2x Frost king layer
  • {eraser around socket on Intel only}
  • 1x Frost king layer
  • Motherboard
  • Blue shop towel
  • Pot backplate
Here are photos of a board with it & here is one after pot & paper towel application. It's a pain initially, but once cut it goes on & off the board very quickly; much more quickly than having to re-do eraser and much less messy than Vasoline.
Old 10-28-2012, 02:48 AM
michael_rw's Avatar
guess i dont have enough posts on OCF to see that first link you posted, but i think i get the idea.. the frost king has adhesive on one side and foil on the other; the foil can be removed though if you gently heat it.. thanks
Old 10-28-2012, 12:51 PM
Actually, the adhesive side is the one from which you remove the foil.
(You have to be signed in to OCF to see images I think.)
EDIT - Nope, wrong...the sticky side is the one without the foil. Pull the foil off and the non-sticky side is underneath.
Old 10-28-2012, 12:54 PM
On my frost king roll, the adhesive is on the opposite side of the foil. You can peel the foil off but underneath it is just the insulation no adhesive
Old 10-28-2012, 08:33 PM
Err...yes, indeed. My memory sucks. Just pulled out my roll and Splave is quite right. Thanks for the error correction!
Old 11-07-2012, 04:29 AM
radi's Avatar
radi radi is offline
hy
do you put vaseline into the socket under the cpu ??
thanks
Old 11-07-2012, 02:04 PM
Viss's Avatar
Viss Viss is offline
Send a message via MSN to Viss
Not needed for LN2, would only consider it when running phase on a daily driver.
Bart
Old 11-08-2012, 06:28 PM
Tsunamijuan's Avatar
Tsunamijuan Tsunamijuan is offline
I went to pickup velcro for the insulation today. They didn't have any decent quality right sized adhesive backed velcro at the hardware store. That wasnt complete fail. Let alone that didnt cost 20$ or more..... So i went to Harbor freight and found a 32"x2" hook loop velcro strap. Which works perfect. Only cost 2$
Get the hot dogs out, this baby's going up in Flames!!!
Old 11-15-2012, 10:05 AM
radi's Avatar
thanks
