Old 09-30-2009, 07:16 AM
miahallen's Avatar
miahallen miahallen is offline
Great guide Peter...thanks!
Old 09-30-2009, 08:21 AM
Karmakazi's Avatar
Karmakazi Karmakazi is offline
Send a message via MSN to Karmakazi
thanks shammy, Ive learned alot from this one!!
Originally Posted by glenboy View Post
super shammy ,you're a mad scientist, i always like looking at your bench setup it always looks like you trying to resurrect frankenstein
Old 09-30-2009, 05:35 PM
SoF's Avatar
SoF SoF is offline
+++1 Tried to find the right words was quite hard, but think you nailed it
Old 10-10-2009, 01:12 PM
Gatman Gatman is offline
Evil kid
Originally Posted by Shammy
For example it’s a voltage to the core of 1.2v then you can pick a 2.5v cap. If a voltage to the Memory say 1.80v then probably a 6.3v cap.
How do you decide to use 2.5v for core and 6.3v for memory? Can't 2.5v work for both? Or even 6.3v for both?
What should the relationship between the output voltage and the cap you use be? I assume there's a benefit to having the cap you pick's rated voltage as close as possible?
Old 10-10-2009, 09:28 PM
MTP04's Avatar
MTP04 MTP04 is offline
Nice guide Shamino, lots of good info...Thanks!
Old 10-11-2009, 12:44 AM
maybe say give a buffer room of 0.3v, between the highest volt u use and the rated cap, so that spikes do not go above the rating.
DDR3s you will be putting in 2+v so best to pick 6.3v.
the higher the voltage rating, the bigger it's size for the same amount of capacitance so theres no point in picking and way too oversized one.
Old 10-12-2009, 12:12 PM
Raja@ASUS Raja@ASUS is offline
ESR can be lower on a larger can capacitor (higher voltage same capacitance), althoug as Sham points out, you run out of sensible sizing range before the ESR will really make a difference to a switching circuit.
Old 10-25-2009, 11:28 PM
saaya saaya is offline
nice guide!
did anybody actually mod his card?
im not sure i understood everything, would be great to have a pic of the final result
Old 10-27-2009, 03:18 AM
I think nothing can be understood 100% without hands on trying out, but i think those who hands on try out stuff can catch this
Old 12-05-2009, 11:51 AM
bazx's Avatar
bazx bazx is offline
peter i am trying the mod out on a 280 gtx
when you say "500+UFs" would it matter if they were 2500 as i have some already or is it best to get some rated @ 500
baz
