Old 11-17-2011, 09:39 AM
Is anybody noticing the recent OC Key firmware giving strange temps? It used to scale roughly with CoreTemp but now appears to be using a different sensor. Somehow I don't think WPrime 1024M at 1.5V & 5GHz is getting in the low mid 50 range on water.
Old 11-17-2011, 10:35 AM
Xtreme Addict's Avatar
Xtreme Addict Xtreme Addict is offline
Great guide
ASUS Polish Overclocking Championship 2010 #1st
MSI MOA 2012 EMEA - #1st
MSI MOA 2012 WW FINALS - #7th
ASUS Open Overclocking Cup AOOC 2012 - #1st
MSI MOA 2013 EMEA Qualifier - #2nd
ASUS Open Overclocking Cup AOOC 2013 - #3rd
MSI MOA 2013 WW FINALS - #3rd
Galaxy GOOC 2013 Finals - #12th
HyperX OC Takeover HOT Final CES 2014 - #1st
G.skill OC World Cup 2014 - #3rd
HyperX OC Takeover HOT 2014 Computex - #1st
Intel OC Challenge Computex 2014 - #1st
MSI MOA 2014 WW Finals - #12th
ASUS Open Overclocking Cup AOOC 2014 -#2nd
Galaxy GOOC 2014 Finals -#4th
HyperX OC Takeover HOT Final CES 2015 - #1st
G.skill OC World Cup 2015 - #5
Old 11-17-2011, 11:59 AM
Originally Posted by Raja@ASUS View Post
Check sub-timings if you are using the max MHz or loose PSC profiles. Some of the third timing sets for W to R are maxxed out to 15 clocks and set spacing for tCCD. Set tCCD to 0 or 4, hurts performance badly if you don't as this is CAS to CAS delay. Minimum spacing is 4 clocks (burst length), 0 just disables the offset logic but reverts to 4 clocks.
With the right timings, DDR3-2400 should be faster than anything lower as memory controller frequency ramps with the divider.
-Raja
you are right, this 16gb kit of RipjawsZ sets it correctly while my 8gb kit of axeram maxes out that value. Also set CLK Period to 2 instead of auto. My fault
Old 11-17-2011, 12:19 PM
if anything it should be reading hotter... unless i uploaded an older version i will have to check
Old 11-17-2011, 12:38 PM
ME4ME ME4ME is offline
Must say using OC Key worked great combined with the subzero temp sensors. Really adds something to the board.
Old 11-18-2011, 04:27 AM
For R4E 0076b
http://www.mediafire.com/?8j5oebpbqyu1i10
Fixes Cold boot problem during High CPU OCs
Old 11-18-2011, 04:46 AM
Latest OC Key Firmware:
http://www.mediafire.com/?ckbunadtx6a0vfn
Old 11-18-2011, 08:49 AM
Great; I'll get those flashed this weekend. Will let you know re: OC Key CPU temp too. Thanks!
Old 11-18-2011, 09:25 AM
what is 00 hang and system power down mean?
102.4 x 49 ddr3 2450 was stable on air but on ln2 (-15c) I get 00 anything over 100 bclk is that just memory controller freaking out?
Old 11-18-2011, 09:31 AM
b1 to 00 or 00 at power on?
b1 to 00 = need to trim imc mhz (use a diff bclk/ratio combi)
