Go Back   kingpincooling.com > KINGPINcooling.com Official Support > Product Support
Product Support Insulation and Usage Guides
Old 11-11-2009, 08:39 PM
Evocarlos's Avatar
Evocarlos Evocarlos is offline
bum lube is by far the best thing to use and washed off with boiling water
our teams mobo from moa2009 it still lives
but Ive taken to the liquid tape just of late just give that extra layer of protection
heres my classy Ive had it less than 24hours
now i just need to get rid of the damn -80 cbb
Old 11-12-2009, 10:54 AM
Viss's Avatar
Viss Viss is offline
Send a message via MSN to Viss
Go a bit colder, many Classified have a certain range in which they wil not boot (mine from -60 to -90) from -91 everything is fine again until cbb for chip
Bart
Old 11-12-2009, 01:42 PM
Evocarlos's Avatar
i,d love to go colder but im on cascade -103c ish it works below -80 (boot to bios) but not above -80 once ive set the ram strap and voltages then boot its fine all the way down to -103
none of the extreme cooling modes make any diffrence
spose im gona hve to put up with it
i do like booting at 35x 140bclk with 1.48v tho
any who im off topic so i,ll go back to me hole
Old 11-12-2009, 05:13 PM
*TMWH*'s Avatar
*TMWH* *TMWH* is offline
I also got this problem, but i got it even lower it think.
Was using dryice, restart the whole system, but it wouldn't start. Didn't cross my mind i will meet a coldbug so early. Didn't have any tempmeter last time, so no exact number.
Old 11-12-2009, 07:18 PM
Evocarlos's Avatar
i fix'd it in the end
x-cool jummper to the right and the s630 bios
Old 11-16-2009, 10:27 PM
Kal-EL's Avatar
Kal-EL Kal-EL is offline
Confident nub
Send a message via MSN to Kal-EL Send a message via Skype™ to Kal-EL
Gosh that's alot of bum lube
OC4JAPAN FUNDRAISER
Old 11-17-2009, 09:34 AM
*TMWH*'s Avatar
Thanks man, will try it out
Old 12-09-2009, 11:34 AM
FireRx's Avatar
FireRx FireRx is offline
I've been using the Vasoline method for quite some time now. The only thing I do different is apply heat from a hair dryer to soften the vasoline in the socket when changing out CPU's. and I agree, use surgical gloves when applying. you don't want contaminates in the socket from your fingers. My classy has been runing 24/7 # 4.5ghz since March 2009. The only time I turn it off is for maintence\dust removal. Can't wait to use the Gulf's in this one. Anyone can tell me the different QXXX of the Core i9's, and which ones will work on a EVGA 759 classified mobo?
Old 12-09-2009, 09:36 PM
Expat GriZ's Avatar
Expat GriZ Expat GriZ is offline
I know Q3QP works in 759....
Old 08-17-2013, 08:35 PM
runmc's Avatar
runmc runmc is offline
Finally got around to reloading these pictures.
