Go Back   kingpincooling.com > KINGPINcooling.com Official Support > Product Support
Product Support Insulation and Usage Guides
Old 10-18-2009, 06:28 AM
Aditya's Avatar
Aditya Aditya is offline
Kalel, does that black colored thingie come off easy afterwards?
Old 10-18-2009, 07:01 AM
i just use Dialectric grease in the socket and around it, and then with armaflex and neopreen.
that works for me.
the back of the motherboard i spray acrylic compound spray.
Old 10-18-2009, 01:07 PM
Kal-EL's Avatar
Kal-EL Kal-EL is offline
Confident nub
Send a message via MSN to Kal-EL Send a message via Skype™ to Kal-EL
Electric Tape Spray. It peels off in patches pretty easy but I think if you lay it on thicker it should peel off easier. Little pieces get stuck in the resistors and such on the mobo and need more time dedicated to picking them off the mobo. It could get tedious but I've never had to clean up these boards for rma.
Ran like this on the 680i, 790i ultra sli, 790i digital FTW and quite possilby soon the E759-x58 (Maybe).
Kneeded eraser seems the way to go if you're worried about rma.
OC4JAPAN FUNDRAISER
Old 10-19-2009, 11:35 AM
Overshocked's Avatar
Overshocked Overshocked is offline
Originally Posted by Deanzo View Post
Eraser won't stick down very well with vaseline on the board.
DOI, forgot about that.
Well i would put a hell of alot of shop towels down then.
Old 10-19-2009, 11:37 AM
I honestly hate kneeded eraser, so im looking for an alternative....
im still worried about RMA though if its a new board. (ive been through a couple classys and im tired of shelling out the dough)
I guess ill try some liquid electrical tape next time then some kneaded eraser over that.
I have used wax before and that works really well, but its hard to remove.
Old 10-23-2009, 10:20 AM
runmc's Avatar
runmc runmc is offline
Vaseline will clean off easily with acetone. Just put some acetone in a spray bottle and tip mobo and spray. I have been benching sub-zero with this board ever since I put up this guide. I haven't had one bit of trouble with moisture. For me it was well worth it. As far as mess goes, the only thing I do that even gets me close to the Vaseline is change out cpus Just keep your hands off the Vaseline.
I'm not suggesting anyone else do this. "It's your thing - do what you wanna do"
Old 10-23-2009, 08:52 PM
Gatman Gatman is offline
Evil kid
http://www.mouser.com/ProductDetail/...avIwFVa9sws%3d
My first choice. No mess, and it ends up being transparent to the point where it's hard to tell that there's anything on the board at all.
Old 10-26-2009, 01:30 AM
Hmmm, and you can put it in the socket as well?
Old 10-26-2009, 11:48 AM
runmc's Avatar
oh yeah.
Old 11-04-2009, 03:01 AM
dinos22's Avatar
dinos22 dinos22 is offline
eraser and vaseline together is a bad idea
either method works fine
i prefer eraser myself....its perfect and not messy but i do use grease as well in combination for memory/PCIe slots etc
Team.AU
Got tube?
GIGABYTE Australia
Need a GIGABYTE bios?
