  #101
Old 06-04-2012, 02:48 PM
check VID table on datasheet for VRM, also I usually disconnect VID from GPU (cut traces for VID near VRM daughter board PCB)
Old 06-04-2012, 03:01 PM
smetankin's Avatar
smetankin smetankin is offline
it`s first, that was done
don`t want to damage more pcb
anything else? please
Old 06-04-2012, 03:16 PM
smetankin's Avatar
vid6/vid7 is always in logical "0"
vid1 - vid5 controlled by dip-switch, lower voltage can`t find with dip.... try 4-5 positions by vrm11 table
Old 06-05-2012, 06:37 PM
smetankin's Avatar
don`t want to damage PCB, enough for me to cut one vcc-trace...try to keep warranty
to bench kepler need vcore more 1,4v, but now I`m going to run card on air... that why I made an individual switch for VID6 to turn on logical "0" when I want... this gives me opportunity to use card in stock
Old 06-05-2012, 09:37 PM
Well, voltage is set exactly by VID code, so if you make levels stready than should have zero problems setting voltage.
Old 06-07-2012, 03:51 AM
michael_rw's Avatar
michael_rw michael_rw is offline
you are trying to keep your warranty? lol. not with all those mods haha
Old 06-07-2012, 04:15 AM
lauracurnowasw007 lauracurnowasw007 is offline
Default mild skin rednes
The VRM section proves to be the best part of the module yet again…Cheers !
mild skin rednes
Old 06-07-2012, 07:37 AM
BenchZowner's Avatar
BenchZowner BenchZowner is offline
Being a good boy :)
LOL @ creative spambot above
Old 06-07-2012, 10:35 PM
walton walton is offline
Default Stage Rental Los Angeles
Great technicality! Must have taken in a lot of effort.
Old 06-11-2012, 11:15 AM
michael_rw's Avatar
wtf spambots.. not cool
