Old 07-14-2015, 09:35 AM
Originally Posted by Bassplayer View Post
Strong... give us photographs!
yes I will definitely upload them after work. I was trying to wait for better camera but I'm broke.
I went to fire it up friday night and everything would shut down instantly. I thought for sure it was the gpu but my psu ended up being dead.
That is 2 corsair ax1200's dead in about a year and a half.
I picked up a 1600 lepa. Hopefully it's ok for xoc. it was so cheap. I'm just worried about tripping the multi rail ocp's.
Anyone have experience with xoc and multi rail.
Old 07-14-2015, 10:48 PM
Pics or never happen.
But seriously, good job there. Keep it up.
First time - you feel like a CERN scientist when thing works. Second time - you having fun, 10th time - it's plain boooring...
i am so terrible at photos. there are a couple grounds you cant see. thanks to romans guide i knew where grounds were under pcb mask. hopefully i can test on cold this weekend. i used little 90 degree angle copper pieces, it was actually really tough because other components were very close. its so much fun though. i wish photos were better.
thanks to all tin's guides for helping me learn so much. i dont think i would know any of this stuff without all tin's info and guides. its really amazing how much you have given to the oc community, thanks
Old 07-14-2015, 11:05 PM
Looking good!
Old 07-14-2015, 11:16 PM
Looking good!
thanks, i edited in some more photos and a big thank you to you at the end. none of this would be possible without you and all your guides and info you share. you really gave me a great hobby in my life and i really appreciate it. hopefully if this goes ok on cold, titan x soon.
i need to clean up the memory board but at first i just did it fast to see if that was my problem, gpu board seems connected very nice. when apply 1.2v with evbot, epower gets 1.25v and gpu gets around 1.245v with almost no fluctuation.
i did put a little to close to pot when installed, epower might be ln2 cooled also, haha.
Old 07-15-2015, 01:52 PM
Nice man....
Old 08-18-2015, 02:03 AM
so the 8800 gts is running really nice. i cant believe i just broke 1200mhz with my last 7 liters tonight. efficiency is terrible and i used wrong driver but that doesnt matter right now, will fix that next run, mem is almost at stock which sucks, quimonda sucks, it really hurts my score, but i ordered new 8800 gts with samsung on ebay.
i added some caps to the back and did a reverse mem voltage mod and also a pll mod, this card is fun to practice with. next run will be much better ran out of ln2 tonight.
Old 08-18-2015, 08:19 AM
Nicely done!
Old 08-19-2015, 02:16 AM
where you measuring voltage from?
whats the maximum voltage your using?
Old 08-19-2015, 12:29 PM
I'm measuring from a resistor on the back, 5 resistors to the right of the top cap I added on the back. I added a measuring cable. I have so many extra probeit cables from evga I just cut the wires off and use those.
If I set 1.5v on my evbot the power card measures just about 1.547v and the spot on the gpu seems almost exactly the same or about 1.546v.
Any higher than 1.5v set on evbot and the bench usually crashes, also it seems after -85c it starts to hurt performance. so 1.547v and -80c seems to be the sweetspot for my card.
But I never benched these back in the day, I wasnt really benching then, so this is my first time with an older card and this card so I could be doing some things wrong. I want to bench it some more to get used to it.
Old 08-19-2015, 02:36 PM
You try setting higher voltage when colder?
