Go Back   kingpincooling.com > The Lounge > Members Rides
Members Rides Brag about your actual ride or your daily pc rig.
Old 09-21-2009, 01:05 PM
ocgmj's Avatar
ocgmj ocgmj is offline
Killer setup Gun.
Old 09-23-2009, 03:21 AM
miahallen's Avatar
miahallen miahallen is offline
Hey GS...you should consider Koolance no-spill quick disconnects for your GFX cards so you don't have to drain the loop every time you want to switch them out.
I just put my Classified on water, and I used the quick disconnects on the mobo blocks so that when I finish a benching run, I can quickly disassemble to dry out (CPU & GPU on LN2) without worrying about draining the water loop. It's very handy
Very nice setup BTW
Old 09-23-2009, 09:07 AM
Very nice setup BTW
I've been meaning to look into those for the convenience factor, just been busy buying other hardware.
Old 12-31-2009, 06:54 PM
A little GPU update.
Old 01-01-2010, 11:38 AM
lakeside2189's Avatar
lakeside2189 lakeside2189 is offline
A True Pure work of art Bro!!!!!!!!!!!!!!
People don't plan to fail. They fail to plan!
Old 01-03-2010, 03:41 PM
MTP04's Avatar
MTP04 MTP04 is offline
I like this picture. It would be sweet if the system could run just like that, with no power cables making it look messy.
Old 01-04-2010, 08:21 AM
*TMWH*'s Avatar
*TMWH* *TMWH* is offline
Yeah, agree on that, looks awesome!
Old 01-04-2010, 09:53 PM
pingpong1455 pingpong1455 is offline
what are the dimensions of the dimas bench ??
and where could i get it ?
Old 01-05-2010, 07:30 AM
http://www.dimastech.it/IT/
Old 01-06-2010, 02:20 PM
Kriztoffer Kriztoffer is offline
Good looking rig
