  #81
Old 01-18-2013, 12:58 PM
Aonoa
Hello,
My cards seem unable to handle higher than 1.2685v without causing my computer to shutdown. I thought these cards should be able to handle 1.3v or even higher? The temperatures are seemingly kept cool enough by the stock air cooling, not even reaching 70C under load with a custom fan profile. I am wondering if this is a natural limit of my cards or if I could do something about it? Would I fare better with water cooling?
OCP setting on normal (extreme setting did not seem to do much) and power target at 131%, only boosted the GPU clock while keeping the mem clock on default.
Thank you for any insight. :-)
Old 01-18-2013, 06:04 PM
Xtreme Addict's Avatar
Xtreme Addict Xtreme Addict is offline
maybe PSU too weak?
ASUS Polish Overclocking Championship 2010 #1st
MSI MOA 2012 EMEA - #1st
MSI MOA 2012 WW FINALS - #7th
ASUS Open Overclocking Cup AOOC 2012 - #1st
MSI MOA 2013 EMEA Qualifier - #2nd
ASUS Open Overclocking Cup AOOC 2013 - #3rd
MSI MOA 2013 WW FINALS - #3rd
Galaxy GOOC 2013 Finals - #12th
HyperX OC Takeover HOT Final CES 2014 - #1st
G.skill OC World Cup 2014 - #3rd
HyperX OC Takeover HOT 2014 Computex - #1st
Intel OC Challenge Computex 2014 - #1st
MSI MOA 2014 WW Finals - #12th
ASUS Open Overclocking Cup AOOC 2014 -#2nd
Galaxy GOOC 2014 Finals -#4th
HyperX OC Takeover HOT Final CES 2015 - #1st
G.skill OC World Cup 2015 - #5
Old 01-18-2013, 06:19 PM
Aonoa
I doubt it, considering I have the NEX 1500. I have it connected directly in a wall outlet, and if the fuse was too weak I imagine there would be other consequences should my PSU attempt to draw too much.
Old 01-18-2013, 08:51 PM
How did you connect your VGA/CPU to PSU? Maybe you just overload some rail, so switch to single-rail mode or reconnect wires to another plugs
Old 01-18-2013, 09:34 PM
Aonoa
I had completely forgotten about the rail configuration, and it may indeed have been the culprit, since it was on multi. I have changed it to single rail now, and early tests seem to indicate success. Thank you. :-)
Old 01-18-2013, 09:46 PM
Welcome
For overclocking I'd suggest use single rail, or watch proper distribution per rails.
Multirail fit's better for 24/7 scenario with increased safety. As you saw - that's working quite nicely shutting down your PC when power draws go beyond the limits
Old 01-19-2013, 01:22 AM
Bobnova Bobnova is offline
Keep in mind that the labels on the plugs do not indicate what rail the plugs are on! Makes it a bit confusing to choose which PCIe plugs to use
Drove myself nuts testing the thing till I figured that out. Eventually said to hell with it and tested in single rail mode.
Old 09-14-2013, 06:13 AM
CHN Overclocking's Avatar
CHN Overclocking CHN Overclocking is offline
In China EVGA rarely sell bad
Old 09-14-2013, 06:18 AM
I tried 1.175V I am a student not have money
